    if __name__ == "__main__"
    3 Posts 0 Posters 444 Views
      On 06/04/2016 at 17:54, xxxxxxxx wrote:
      I seem to be having a hard time understanding why this line is here.
      	doc = c4d.document.GetActiveDocument()
      	print doc
      I understand that this quick sample will execute the main() function. What's the difference then if the code does this?
      	print doc
      Obviously it's not going to run a main() function because now it doesn't exist.
      You get the same result though.
      Is one way preferred over another?
      What would be the reason to use one over the other?
      I feel like I'm mostly confident in programming but this seems like a glaring oversight in fundamentals on my part as to why I don't understand this.
        On 07/04/2016 at 02:06, xxxxxxxx wrote:
        the line " if __name__ == "__main__"" is a typical Python idiom. It is used to distinct between loading the code (in a module) and executing the code.
        Using a main() function makes no different but like any other pattern it is useful to organize the code.
        See also
        • __main__ — Top-level script environment
        • What does if \__name\_\_ == "\__main\_\_": do?
          On 15/04/2016 at 09:12, xxxxxxxx wrote:
          Hello Herbie,
          was your question answered?
