    Get Texture Tag and set RestrictSelection
    3 Posts 0 Posters 511 Views
      On 17/02/2003 at 21:55, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      This one (or two ) has me stumped.  How do I find a Texture Tag associated with a known object, by name?  Currently, I'm just using BaseObject->GetTag(Ttexture, i) in a loop until it finds it (or not) using String == operator.
      Then, how do I set the Texture Tag's "Selection" (formerly known as "Restrict to Selection") to a known String (which equals a PolygonSelection Tag)?
      Thanks much,
      Robert
        On 17/02/2003 at 23:24, xxxxxxxx wrote:
        In C++ this is easy:
             BaseObject* obj = doc->GetFirstObject();
             TextureTag* tag = static_cast<TextureTag*>(obj->GetTag(Ttexture, 0));
             GeData matlink;
             tag->GetParameter(DescID(TEXTURETAG_MATERIAL), matlink, NULL);
             BaseMaterial* mat = static_cast<BaseMaterial*>(matlink.GetLink(doc, Mbase));
             GePrint(mat->GetName());
        And for the restriction:
             tag->SetParameter(DescID(TEXTURETAG_RESTRICTION), GeData("Restriction"), NULL);
        All found in Ttexture.res.
          On 18/02/2003 at 06:18, xxxxxxxx wrote:
          And here, I'm searching the lib's .h and .cpp files... :0)
          Thank you, Mikael!
          Robert
