    Time of a specific frame
    2 Posts 0 Posters 346 Views
      On 04/03/2016 at 04:37, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Hello.
      Which is the best way to get the time of a specific frame (not current) in document ?
      BaseDocument's GetTime returns the time of current time.
      I need to give the frame as parameter and get the time in the same document.
      Thank you.
        On 04/03/2016 at 06:16, xxxxxxxx wrote:
        It would seem that if you get the frames-per-second (FPS) from the document it is simply a matter of setting time = frame / document->GetFps().  So you could call BaseTime setting the numerator (frame) and the FPS (denominator) separately.  or simpler yet is to construct the BaseTime using the constructor:
        BaseTime frameTime = BaseTime(frame, fps);
        This sets both the numerator to the frame value and the denominator to the frames-per-second value.  This is why you really don't need a method in BaseDocument that gets the time of the frame (but you do need a method that gets the frame at a time because of the internal storage of time in BaseTime).
