    BFM_INPUT_MOUSEWHEEL message
    SDK Help
    0
    11
    917
    • H
      On 27/01/2016 at 08:29, xxxxxxxx wrote:
      Cinema 4D Version:   R13
      Hello all,
      In Attribute window, when I rotate mouse wheel (over a combobox control) the value is changing and I want to inhib this operation.
      On Message(const BaseContainer& msg, BaseContainer& result) method (inherited from iCustomGui),
      if I rotate mouse wheel
      LONG ch = msg.GetLong( BFM_INPUT_CHANNEL );
      the result is ch = 0;
      My expectaction was ch = 100 (which means "BFM_INPUT_MOUSEWHEEL")
      If I click on mouse wheel the result is ch = 3 (which means "BFM_INPUT_MOUSEMIDDLE")
      Can you help me please, why the result is 0 when I rotate the wheel?
      Or do you have an other ideea how to do?
      Thank you,
      Daniel
      • H
        On 28/01/2016 at 04:47, xxxxxxxx wrote:
        in a GeDialog (same for your iCustomGui) this is roughly how expected it to work:
        You check the incoming message:
        msg.GetId() == BFM_INPUT
        You check the device:
        msg.GetInt32(BFM_INPUT_DEVICE) == BFM_INPUT_MOUSE
        And then check the channel:
        msg.GetInt32(BFM_INPUT_CHANNEL) == BFM_INPUT_MOUSEWHEEL
        Seems to work quite well here. If you continue to have this issue, can you please reveal a bit more of your message function?
        • H
          On 29/01/2016 at 07:54, xxxxxxxx wrote:
          and sorry for my delay...
          On "Command" method (from "class MyClass: public iCustomGui") I have:
          Bool MyClass::Command(LONG id, const BaseContainer &msg;)
             switch (id){
                case IDC_COMBO_WPROP_TYPE:
                  //here is my combobox and over it I rotate the mouse wheel
                  LONG lId = msg.GetId();
                  if (lId == BFM_INPUT)
                  int a = 5;   // something
          LONG chn = msg.GetLong( BFM_INPUT_CHANNEL );
               if (chn == BFM_INPUT_MOUSEWHEEL)
                  int i = 9;   // something
                break;
             return iCustomGui::Command(id, msg);
          Here "lId" is 0x62414354 = "bACT" which means "BFM_ACTION" not "BFM_INPUT"
          Can I see on "Command()" if the mouse wheel is rotated?
          Thank you,
          Daniel
          • H
            On 29/01/2016 at 08:50, xxxxxxxx wrote:
            and chn is 0
            • H
              On 30/01/2016 at 07:46, xxxxxxxx wrote:
              I could be wrong about this.
              But if you're trying to test for the rotating mouse wheel while hovering over a gizmo on a GeDialog. I don't believe that's possible.
              I think the gizmo's ability to catch mouse wheel values is private. And not supported in the SDK.
              The only places I know where we can catch the rotation values of the mouse wheel are:
              -The Editor view
              -A User Area attached to a GeDialog
              Detecting it anywhere else would require coding directly to your OS.
              But I could be wrong.
              • H
                On 01/02/2016 at 00:43, xxxxxxxx wrote:
                Thank you Scott for your info
                • H
                  On 01/02/2016 at 01:15, xxxxxxxx wrote:
                  In Attributes window I have some comboboxes like in the below attached picture (inherited from iCustomGui) and I want to inhibit the changing of values when I rotate the wheel of mouse over combobox.
                  Daniel
                  • H
                    On 01/02/2016 at 02:04, xxxxxxxx wrote:
                    I'm really not sure what the issue is. I mean, as you wrote, you already get the BFM_ACTION in your Command() function, when using the mousewheel on the combobox.
                    I tried it here, in a GeDialog and it works just as expected.
                    In your code example, you are of course evaluating things, that are not there. You are checking for BFM_INPUT and regardless of the result you try to evaluate the channel.
                    Instead, you should evaluate, what you have received, as you said BFM_ACTION.
                    And in my tests here, if the message ID is BFM_ACTION, I can simply read the BFM_ACTION_VALUE to get the new value of the combobox.
                    • H
                      On 01/02/2016 at 04:40, xxxxxxxx wrote:
                      Hi Andreas,
                      Yes, you are right that I didn't evaluate correctly the result of BFM_INPUT... I did only some tests...
                      My combobox is added in "CreateLayout()" with "AddComboBox" (which is from GeDialog)
                      Bool iWidgetPropertyGui::CreateLayout( )
                      AddComboBox(IDC_COMBO_WPROP_TYPE,BFV_TOP|BFH_LEFT,SizePixChr(80,10),SizePixChr(10,1));
                      Is it possible to have this behaviour because I use Cinema4D R13 variant?
                      Thank you,
                      Daniel
                      • H
                        On 01/02/2016 at 04:57, xxxxxxxx wrote:
                        Well, usually we don't support versions older versions than the current one.
                        But I don't see a reason, why it shouldn't work in R13. Haven't tried it though.
                        • H
                          On 01/02/2016 at 05:19, xxxxxxxx wrote:
                          To be more explicit this is my window and in green area I can catch "BFM_INPUT_MOUSEWHEEL" and "BFM_INPUT" messages.
                          I understand that the combobox consumes this message and it is not forwarded...
