    Is there a filename gui for a GeDialog? [SOLVED]
    5 Posts 0 Posters 669 Views
      On 24/01/2016 at 11:21, xxxxxxxx wrote:
      hey all,
      I just feel kinda dumb but.. I can't find a filename gui for a GeDialog.
      So I just wanted to ask you guys (since  you all have more experience) if there is one.
      I would need it to set Textures for a certain material channel.
      Thanks in advace!
      grettings,
      neon
        On 25/01/2016 at 01:39, xxxxxxxx wrote:
        there is no "primitive" filename dialog gadget. The filename GUI element is made of a default string gadget and a default button gadget. You can create this custom GUI element with AddCustomGui(). The ID of the filename GUI is CUSTOMGUI_FILENAME. The value stored with the GUI element can be accessed with SetString() and GetString():
        self.AddCustomGui(self._filename, c4d.CUSTOMGUI_FILENAME, "", c4d.BFH_SCALEFIT, 50, 10, c4d.BaseContainer())
        self.SetString(self._filename, "C:\\justsomefile.png")
          On 25/01/2016 at 08:54, xxxxxxxx wrote:
          Hey S_Bach,
          thanks for your reply, your really helped me alot!
          But if there actualy is a customgui, why isn't it in the documentation then?
          greetings,
          neon
            On 25/01/2016 at 09:18, xxxxxxxx wrote:
            the Python API is an incomplete copy of the C++ API so you find a lot relevant information also in the C++ documentation, in this case you find the CUSTOMGUI type.
              On 25/01/2016 at 11:43, xxxxxxxx wrote:
              Hey Sebastian,
              thanks for the tip, didn't know it was an actual copy of the c++ sdk.
              greetings,
              neon
