    Clone the document along with its cache
    2 Posts 0 Posters 299 Views
      On 24/01/2016 at 03:15, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Hello.
      I have the following scene:
      1. Sphere
      2. Polygonized plane with a collision deformer pointing to the above sphere.
      3. a cube with a bending deformer
      The plane covers the sphere like a blanket.
      Now, i need to create a clone of this document, so i use:
      1. The GetClone with COPYFLAGS_DOCUMENT.
      2. On the cloned document, i use the execute passes with true in animation, expressions and cache parameters.
      After traversing the nodes with GetCache/GetDeformCache recursion method,
      i notice that the plane stays horizontal instead of covering the sphere (loses its cache maybe ?).
      However, the cube preserves its deformable state.
      If i also use the Hierarchy class and call Run on the cloned document,
      the plane appears correctly, while the sphere disappears and the cube appears broken.
      So, my question is: How do i have to use the GetClone, ExecutePasses and the Hierarchy class to produce
      the correct cached cloned document exactly as it appears in the viewport ?
      Thank you for your time.
        On 25/01/2016 at 09:28, xxxxxxxx wrote:
        can you please provide us with some code, that shows how you exactly try to do this? And also when or where you are trying to execute that code?
