    Installing numpy
    27 Posts 0 Posters 19.8k Views
      On 22/01/2016 at 07:46, xxxxxxxx wrote:
      I've compiled Py2.7 binaries that work with R17 for you yesterday. Look again in the Google Drive folder in numpy-1.10.4
      Thanks for the R17 version.
      It is partly working (I might do something wrong) :
      Here is what I do in the script, after loading the class _localimport(object)
          with _localimport('d:/modules') :
              import numpy as np
          assert 'numpy' not in sys.modules
          print np.__version__
          print np.__git_revision__
          print (sys.version)
          x = np.array([1,2,3])
          print x
      The version (1.10.4), git version and sys.version are correctly printed.
      But the last line - print x - gives the following error message:
      -Pim
        On 22/01/2016 at 08:28, xxxxxxxx wrote:
        Hey Pim,
        one one hand this is an limitation of doing local imports. I personally think that it's bad style, but some
        modules do some imports from functions, thus leading to a delayed import outside of the local import
        context. This is only problematic for relative imports or for imports of modules that are also in the
        local import context.
        You can actually re-use the local import context if you know your function is doing an import somewhere
        down its call hierarchy that would otherwise fail. Now there's the other hand, there is actually a bug that
        will not let you do this in localimport 1.4.10. It's fixed in 1.4.11 (that I have just added).
        See NiklasRosenstein/localimport#15.
        imp = _localimport('d:/modules') :
        with imp:
          import numpy
        arr = numpy.array([1, 2, 3])
        with imp:
          print(arr)
        Keep in mind that entering the local import context is a relatively costly  operation. Also note that it
        must not be done from a threaded context as it fuzzes with the global importer state.
        On a final note, for big extensions like numpy and libraries that pose problems as such, it might be best
        to provide the user with installation instructions and not use local import at all.
        Best,
        -Niklas
          On 22/01/2016 at 08:34, xxxxxxxx wrote:
          Hey Niklas,
          Thanks for the explanation.
          Ok, so local import is not the best option.
          What is the best way not to use a local import?
          -Pim
          PS I do not see 1.4.11 in the Google Drive.
            On 22/01/2016 at 09:15, xxxxxxxx wrote:
            Hey Pim,
            well the only alternative you go is to actually install the package to the Cinema 4D python package
            location in the preferences folder  Cinema 4D R17_BlablaPreferences/library/python/packages/win64/
            or update your PYTHONPATH  environment variable.
            If you're going to distribute your plugin, you'll have to tell users to download and install the numpy
            package to the preferences folder so the plugin can import it.
            localimport is on GitHub, not Google Drive. 🙂
              On 22/01/2016 at 11:48, xxxxxxxx wrote:
              Great, it is working now.
              And sorry, I did not read your post correctly.
              It is indeed on GitHub.
              Could you tell something on how to compile the numpy source, so it can be used by cinema 4d.
              And I know I am asking very much, but can you do something similar for the opencv library?
              -Pim
                On 22/01/2016 at 19:33, xxxxxxxx wrote:
                Hello Niklas
                Thanks for works.
                Can i ask, are you using of craftr or build instructions at http://www.scipy.org/scipylib/building/windows.html
                Pim, take to look at main pages of py modules how to build them
                You are asking about opencv - http://docs.opencv.org/master/d5/de5/tutorial_py_setup_in_windows.html#gsc.tab=0
                  On 23/01/2016 at 01:01, xxxxxxxx wrote:
                  @Pim I wrote myself a little blog entry to not forget how to compile that stuff in the future.
                  See https://niklasrosenstein.com/2016/01/compile-python-c-extensions-for-cinema-4d-r17-windows/
                  Maybe you can just follow the instructions for OpenCV.
                  @Ilya I'm not using Craftr to compile the Python modules, just the setup.py  that is delivered with
                  Python package. I wasn't able to compile SciPy on Windows the last time though.
                    On 23/01/2016 at 10:03, xxxxxxxx wrote:
                    Great, I am going to try it.
                      On 25/01/2016 at 04:18, xxxxxxxx wrote:
                      Some questions:
                      1- do I need a python environment for the setuptools and for building?
                      2- where in this process do I use visual studio?
                      3- I have vs express 2012. I guess I must upgrade at least to 2013 for r17?
                      4- I guess for a dll, a .h files is also needed, or some sort of file to indicate what is in the dll?
                      Questions, questions, questions.
                      I hope that you can help and that I can do something in return.
                      -Pim
                        On 25/01/2016 at 05:10, xxxxxxxx wrote:
                        Progress:
                        Step 1. Install Setuptools
                        I installed it using Powershell and the correct link to python:
                        (Invoke-WebRequest https://bootstrap.pypa.io/ez_setup.py).Content | c:\python27\python -
                        Looking at step 2, I now realize that cinema 4d has already a complete python environment.
                        So, I have to install Setuptools, now using the cinema 4d python environment.
                        I now understand better the sub steps in your blog:
                        > set PY=C:\maxon\Cinema 4D R17\resources\modules\python\Python.win64.framework\python.exe
                        > cd setuptools-19.4\
                        > call "%PY%" setup.py install
                        I change 1.1 to my own correct folder and executed it in windows cmd.
                        I copied setuptools-19.6 (for me it is -6 and not -4) to the cinema python folder.
                        I did step 1.2 so now the current folder is the setuptools-19.6 folder.
                        I executed step 1.3 call "%PY%" setup.py install and there is goes wrong:
                        The filename, directory name, or volume label syntax is incorrect.
                        What am I doing wrong?
                        -Pim
                          On 26/01/2016 at 03:30, xxxxxxxx wrote:
                          Progress 2.
                          I added python to the windows path.
                          Started up cmd, went to to the folder C:\Program Files\MAXON\CINEMA 4D R17\resource\modules\python\Python.win64.framework\setuptools-19.6
                          and gave the command:
                          > python setup.py install
                          "Finished processing dependencies for setuptools == 19.6"
                          So everything seems ok.
                            On 26/01/2016 at 04:19, xxxxxxxx wrote:
                            Progress 3.
                            Step 2. Modify your Python include and libs folder
                            The include and libs each contain a python27 subdirectory.
                            You need to move the contents of this directory one level up so they files are directly in the include/libs folder.
                            Which folder should be moved one level up.
                            libs to include or include to libs.
                            Skip this one and I proceed to Step 3.
                            Step 3. Build the Python Extension
                            This example uses NumPy.
                            First, download the source code from GitHub or another mirror and unpack it.
                            After the package is built, a binary distribute will be created as a ZIP file.
                            I downloaded Numpy and unzipped it to 😄 emp
                            The I gave the command:
                            😄 emp\numpy-master\python setup.py install
                            This gave the error message:
                            RuntimeError: Running cythonize failed!
                            Awaiting an answer, I go back to plan B: Install the binary.
                              On 26/01/2016 at 05:47, xxxxxxxx wrote:
                              Progress 3.
                              Installing the binary.
                              - I downloaded pip and installed it using the get-pip.py script
                              - from http://www.lfd.uci.edu/~gohlke/pythonlibs/
                              I downloaded numpy-1.10.4+mkl-cp27-none-win_amd64.whl
                              Note: cp27 indicates it is for python 2.7
                              Went to the folder where pip.exe is located and gave the command:
                              pip install 😄 emp\numpy-1.10.4+mkl-cp27-none-win_amd64.whl
                              Result: Successfully installed numpy-1.10.4
                              - started python and said import numpy
                              This gave the same result as described in this post.
                              So, I need to recompile numpy.
                              Back to square 1.
                              -Pim
                                You actually need to omit the quotes, I'll correct that in my blog post. Just call %PY%
                                Are you sure just plain "python" is the right Python installation (the on in the Cinema 4D framework)?
                                What's more to the error message? I didn't get a "cythonized failed" error.
                                [quote]Installing the binary.
                                Back to square 1.
                                Might be coming from the fact that its not compiled with the right Visual Studio version.
                                I just read in the post you linked that Andreas said it must be VS2012 SP4, interestingly it
                                worked with VS2008 here too.
                                  On 26/01/2016 at 09:15, xxxxxxxx wrote:
                                  See below the full error messages.
                                  Python links to the cinema 4d python environment / folders:
                                  C:\Program Files\MAXON\CINEMA 4D R17\resource\modules\python\Python.win64.framework\python.exe
                                  The big question is: how to compiled with the right Visual Studio version?
                                    On 26/01/2016 at 09:50, xxxxxxxx wrote:
                                    FYI. I tried to reply to your PM pgrooff. But your inbox is full.
                                    I personally don't bother to compile these things myself.
                                    I use many of the common Python libraries via Anaconda.
                                    And the precompiled version of opencv3.1.exe installs both the C++ and Python libraries.
                                    The quick and simple way to install this stuff:
                                    -Install Anaconda(or python 2.7 if you prefer) and install opencv.exe with their installers
                                    -Then put the opencv cv2.pyd file in the Anaconda site-packages folder
                                    -Then copy the entire Anaconada folder to the C4D folder where Python.win64.framework is
                                    -Rename Python.win64.framework to: Python.win64.framework_original
                                    -Rename the copied Anaconda folder to:Python.win64.framework
                                    -Boom...Done
                                    No fuss...no muss...no cocoanuts.😉
                                    I only compile things myself when I have absolutely no other choice.
                                    *** Public Service Announcement Here ***
                                    It might be frowned upon by Maxon to replace their python installation with another python installation.
                                    But it's the easiest way to do it. And so far I've never seen any problems doing it.
                                      On 29/01/2016 at 09:33, xxxxxxxx wrote:
                                      Sorry, my fault (although 5 is a bit small!).
                                      Thanks for the information. I will try it and let you know!
                                      -Pim
                                        On 29/05/2016 at 01:56, xxxxxxxx wrote:
                                        Niklas,
                                        Thanks for all this.
                                        There is one more thing missing....isn't there always!
                                        Are you going to put up a numpy for R17 (2.7) on a mac?
                                        I don't see it.
                                          On 30/05/2016 at 16:00, xxxxxxxx wrote:
                                          Just added numpy-1.11.0 for Python 2.7 (Mac) here: https://public.niklasrosenstein.com/PythonBinaries/numpy-1.11.0/
                                            On 03/06/2016 at 00:22, xxxxxxxx wrote:
                                            Niklas,
                                            Thanks for all you do here!
                                            Chris
