    pass and userpass in tokensystem [SOLVED]
    4 Posts 0 Posters 531 Views
      On 19/01/2016 at 11:11, xxxxxxxx wrote:
      I'm trying to use FilenameConvertTokens to replace all the tokens in my file path but $pass and $userpass aren't getting replaced.
      I'm assuming that I'm not building up my RenderPathData dictionary properly. I'm not clear on what _rBc should be. The docs show that it should be a BaseContainer and the example calls it renderSettings but I'm not sure how to get that information. Currently, I have it set to:
      rpData = {
      	'_doc': doc,
      	'_rData': doc.GetActiveRenderData(),
      	'_frame': doc.GetTime().GetFrame(doc.GetFps())
      I'm also adding a take if it's supported but that's probably not important to this question.
      Anyways, hopefully someone can point me in the right direction.
      Eric
        On 20/01/2016 at 01:46, xxxxxxxx wrote:
        Hello and welcome,
        the Python API is a copy of Cinema's C++ API so you find also a lot useful information in the C++ documentation, also about the Token System.
        The RenderPathData dictionary is based on the corresponding object in the C++ API: RenderPathData Struct Reference
        So you see the that you could use "_layerTypeName" and "_layerName".
        The "_rBc" BaseContainer should contain the render settings. You can get these settings from the document's RenderData:
        renderData = doc.GetActiveRenderData()
        renderSettings = renderData.GetData()
          On 29/01/2016 at 10:01, xxxxxxxx wrote:
          Hello Eric,
          was your question answered?
            On 29/01/2016 at 10:03, xxxxxxxx wrote:
            Hey Sebastian,
            Yeah, I was able to figure it out.
            Eric
