    Object Data Plugin Help [SOLVED]
    5 Posts 0 Posters 589 Views
      On 25/12/2015 at 07:38, xxxxxxxx wrote:
      Hey there,
      here is my problem:
      I have made an object and in the .res file I made a button that should, when pushed, open a seperate plugin, and I don't really know how to do that. Do I have to write the code into the ObjectData's Execute method or where do I have to write my code?
      hopefully everything is clear ^^
      (sorry fo my bad english)
      wish you guys a nice Chtistmas day!
      greetings,
      neon.
        On 25/12/2015 at 12:52, xxxxxxxx wrote:
        No, in the "Message" method. Straight from the python doc:
        def Message(self, node, type, data) :
            if type==c4d.MSG_DESCRIPTION_COMMAND:
                if data['id'][0].id==THE_BUTTON_ID:
                    print "Pushed button with command ID", THE_BUTTON_ID
        The method "Message" is inherited from NodeData.
          On 04/01/2016 at 01:50, xxxxxxxx wrote:
          as Cairyn shows, the button is catched in NodeData.Message().
            On 15/01/2016 at 09:20, xxxxxxxx wrote:
            Hello Neon,
            was your question answered?
              On 20/01/2016 at 08:36, xxxxxxxx wrote:
              Hello S_Bach,
              sorry for the late answer, I had to much work to do for school, that I could't even take a look in the forum and wrire a reply, really sry for that!
              But yes, my question was answered, thank you two ^^
              neon
