    Restore old Pointselection
    9 Posts 0 Posters 993 Views
      On 22/12/2015 at 02:45, xxxxxxxx wrote:
      Hi, I want to store a Pointsselection and later restore that Selection on another Identical Object.
      I tried this...but with no luck
      points = obj.GetPointS()
      count =  NewObj.GetPointCount()
      newPoints = NewObj.GetPointS()
      newPoints.DeselectAll()
      for i in xrange(count) :
      	if points.IsSelected(i) :
      		newPoints.Select(i)
        On 22/12/2015 at 03:02, xxxxxxxx wrote:
        Hi Holgar,
        You can simply use BaseSelect.CopyTo() to copy a selection to another. Note you have to send a MSG_UPDATE after changing the selection:
        sel = obj.GetPointS()
        otherSel = newObj.GetPointS()
        sel.CopyTo(otherSel)
        newObj.Message(c4d.MSG_UPDATE)
          On 22/12/2015 at 03:49, xxxxxxxx wrote:
          Thanks Yannick. But it does not work for me. What I do is I make CallCommand with Shrinkselection and than I want to restore the old selection. Its not working.
            On 22/12/2015 at 03:52, xxxxxxxx wrote:
            Could you post some code?
              On 22/12/2015 at 04:16, xxxxxxxx wrote:
                  selobj=doc.GetSelection()
                  obj=selobj[0]
                  obj.Message(c4d.MSG_UPDATE)
                  c4d.CallCommand(12559) # Shrink Selection
                  newobj=obj.GetClone()
                  newobj.InsertAfter(obj)
                  otherSel = newobj.GetPointS()
                  newobj.Message(c4d.MSG_UPDATE)
                  obj.Remove()
                On 22/12/2015 at 05:26, xxxxxxxx wrote:
                Just some question:
                Why dont you use doc.GetActiveObject() or doc.GetActiveObjects?
                You just wanna work with Objects, rigth?
                Why do you send this message befor the selection change?
                Isnt it more comfortable to use
                c4d.utils.SendModelingCommand(command = c4d.MCOMMAND_SELECTSHRINK,
                                                list = [selobj],
                                                mode = c4d.MODELINGCOMMANDMODE_POINTSELECTION,
                                                bc = c4d.BaseContainer(),
                                                doc = doc)
                Ok, in this case selobj is the active object in any cases.
                And finally just to clearify:
                - you store the selection of an object
                - you shrink the selection
                - you create and insert a clone of the object with the shrinked selection
                - you put the unshrinked selection at the clone and remove the object
                Where is the difference before and after the script?
                  On 22/12/2015 at 06:19, xxxxxxxx wrote:
                  This is just an example copied from a script. I store the selection before I shrink the selection. So I would expect i can restore it later from the state before I shrink it. But I guess something is wrong with my logic.
                    On 22/12/2015 at 06:33, xxxxxxxx wrote:
                    Ok, I understand.
                    I think sel isnt an instance or clone of obj.GetPointS(), so you change sel with SELECTSHRINK, too.
                    from c4d import gui
                      obj = doc.GetActiveObject()
                      if obj == None: return
                      sel = c4d.BaseSelect()
                      obj.GetPointS().CopyTo(sel)
                                                  list = [obj],
                                                  doc = doc)
                      newobj = obj.GetClone()
                      newobj.SetRelPos(c4d.Vector(0,0,200))
                      other_sel = newobj.GetPointS()
                      sel.CopyTo(other_sel)
                      On 23/12/2015 at 00:30, xxxxxxxx wrote:
                      so How would I be able to restore my old selection than? Any Idea?
                      Edit: Sorry..just realized that your code is now working. I see. Thanks.
