    Global event messages
    7 Posts 0 Posters 791 Views
      On 01/12/2015 at 13:05, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Hello.
      There are some messages that are received from CoreMessage but are not mentioned in ge_prepass.h
      1970300003
      1018484
      1431323715
      When are these messages triggered ? I have searched the whole framework and couldn't find any reference for them.
      Thank you for your time.
        On 02/12/2015 at 07:11, xxxxxxxx wrote:
        Howdy,
        Those messages could either be private or possibly a plugin, so there may be no way for you to know.
        Adios,
        Cactus Dan
          On 02/12/2015 at 07:25, xxxxxxxx wrote:
          One way to know would be to remove all 'third-part' plugins and see if the messages persist.  If they do, then they are almost assuredly private messages.
            On 02/12/2015 at 12:55, xxxxxxxx wrote:
            Hi guys,
            another way to know would be to ask SDK Support... oh wait, you already did 😉
            1018484 internally is MSG_PSLIDER_UPDATE, which is for internal use and is basically sent together with EVMSG_CHANGE (and a few other messages).
            1970300003 (0x75706463, 'updc') : BFM_CORE_UPDATECOMMANDS (updates all command buttons), it's being send, when icons need to be updated.
            1431323715 (0x55504443, 'UPDC') : internal message BFM_UPDATECONSOLE, and it's send, when the Console dialog needs to be updated.
            I don't think, you should (or need to) care about these messages. All of them have pretty specific internal use and are not really meant for public use.
              On 02/12/2015 at 12:58, xxxxxxxx wrote:
              My next question was going to be why are you concerned about these messages.  One suspects over-reaching control but I could be mistaken.
                On 02/12/2015 at 13:59, xxxxxxxx wrote:
                Thank you for your replies !
                I need to do some calculations when any object of the hierarchy changes.
                I will do it in document recalculated event.
                Thnx again.
                  On 02/12/2015 at 14:39, xxxxxxxx wrote:
                  What scope of changes?  Most existing messages will notify of creation/deletion/transforms/modifications. Even plugin changes should invoke some message from C4D unless implemented poorly (no AddUndo() or something).  I would use what is available and worry about outliers if they materialize.
