    NetSendData() custom data/messages
    SDK Help
    0
    • H
      On 10/11/2015 at 14:53, xxxxxxxx wrote:
      Cinema 4D Version:   16
      Is it possible to send custom messages with NetSendData()? It seems like when I pass my own plugin
      ID, I always get MESSAGERESULT_UNKNOWN error and the message is not sent to the TR server. Small
      example:
      struct NetRenderMsgVbGi
        UInt size;
        Bool compute, wait;
      NetRenderBuffer msg, result;
      msg.id = MSG_NETRENDER_VB_GI;
      msg.job = vps->net->_renderJob->GetUuid();
      msg.size = 0;
      msg.data = nullptr;
      MESSAGERESULT res = NetSendData(
        vps->net->_service, vps->net->_renderJob->GetServerUuid(), &msg, &result, vps->thread);
      Thanks in advance,
      -Niklas
      • H
        On 11/11/2015 at 02:30, xxxxxxxx wrote:
        using R17 I have no problems using this code to send a message:
        Int32* payload = NewObjClear(Int32, 1);
        *payload = 123;
        // prepare message
        NetRenderBuffer requestMessage;
        requestMessage.id                        = MSG_CUSTOM;
        requestMessage.job                    = data->_vps->net->_renderJob->GetUuid();
        requestMessage.size                    = SIZEOF(Int32);
        requestMessage.data                    = payload;
        NetRenderBuffer requestResult;
        requestResult.id                    = MSG_CUSTOM;
        requestResult.job                    = data->_vps->net->_renderJob->GetUuid();
        requestResult.size                = 0;
        requestResult.data                = nullptr;
        NetSendData(data->_vps->net->_service, data->_vps->net->_renderJob->GetServerUuid(), &requestMessage, &requestResult, data->_vps->thread);
        if(requestResult.data)
         Int32* res = (Int32* )requestResult.data;
         GePrint("Got data from server: " + String::IntToString(*res));
        • H
          On 11/11/2015 at 03:29, xxxxxxxx wrote:
          Hi Sebastian, thanks for the example. Seems like you really need a payload, it doesn't work without here
          in R16. Strangely, it works without payload for sending standard Net messages (eg. MSG_NETRENDER_BUCKET_INFO or ~_INDEX).
          One thing I'm still wondering about though is about byte order. Won't there be issues with
          machines that communicate with this interface and use a different byte order?
          -Niklas
          • H
            On 13/11/2015 at 00:25, xxxxxxxx wrote:
            according to the developers, you are responsible for the endianess of the data chunk stored in NetRenderBuffer::data.
