    ResEdit: Bug Reports & Ideas
    Scheduled Pinned Locked Moved General Discussion
    17 Posts 0 Posters 4.0k Views
      On 04/11/2015 at 04:20, xxxxxxxx wrote:
      Thanks. I'm still not sure how to compile your version on osx though. Maybe you could include a XCode project in the repo? I have no idea how to set that up 🙂
      -b
        On 04/11/2015 at 04:48, xxxxxxxx wrote:
        So you want to compile it yourself and not use the downloaad from the "Releases" page? Just want to be sure before I spend time writing instructions. 😉
          On 04/11/2015 at 04:50, xxxxxxxx wrote:
          Blush. Didn't think about that 🙂
          -b
            On 04/11/2015 at 05:09, xxxxxxxx wrote:
            Hello
            I don't know how to make request at github, always use Issue feature.
            I'm interesting why ResEdit has not feature to edit and create resource for NodeData or for 'linear' Container gui. Or if missed somewhere, i'm sorry
              On 04/11/2015 at 06:23, xxxxxxxx wrote:
              @Bonsal: Maybe you skipped it but I wrote about it in my first reply already 🙂
              @Ilya: Just create an Issue with your request, it doesn't need to be a bug report but can be anything related.
              ResEdit was not constructed for editing description resources, I think making it work with these as well would be more work than an actual new plugin.
                On 04/11/2015 at 06:39, xxxxxxxx wrote:
                Nikals, thanks
                As i understand edit of dialogs is possible by saving of macro-file(last construction) and import of it for edit >>> yes for new project
                Main question, maybe not for you, for someone from sdk teamers or c4d dev team - was how easy to make gui of object, tag, xpresso-node
                i often found questions about IDE for GUI in scripting/programming sections at other forums
                Upd.
                I remember a few tools from Lazaros aka Nitroman, Scott Ayers to make resources
                Ha, Niklas i remember yours - http://forums.cgsociety.org/showthread.php?p=7033391#post7033391
                  On 04/11/2015 at 07:36, xxxxxxxx wrote:
                  I need new glasses...
                  -b
                    Nikals, thanks
                    I find writing description resources by hand very easy compared to dialog resources.
                    Upd.
                    I don't know any other tools to be honest, but that one's years old and pretty bad Tongue
                      On 05/11/2015 at 07:59, xxxxxxxx wrote:
                      Btw, I just added an R16 Windows build available here.
                        On 05/11/2015 at 09:36, xxxxxxxx wrote:
                        I've never made any resource tools.
                        You might be thinking of a C# app I wrote to help create GeDialog plugins in C.O.F.F.E.E.
                          On 05/11/2015 at 11:12, xxxxxxxx wrote:
                          I've just uploaded a new version with a bunch of fixes: https://github.com/nr-plugins/resedit/releases/tag/v1.2
                            On 06/11/2015 at 20:08, xxxxxxxx wrote:
                            Hello
                            Thank you for reply and updates.
                            Also does craftfile be for your Creator?
                              On 06/11/2015 at 23:18, xxxxxxxx wrote:
                              There's some (rough) build instructions here: https://github.com/nr-plugins/resedit/blob/master/README.md#build-instructions
                              I've been working on another prototype called Craftr and found it to be
                              superior. Creator is deprecated. 🙂
                              Best, Niklas
                                Best, Niklas
                                Thanks 👍
                                Slighter differ as scons(or exscons for cg)
