    Layer Shader Layers
    5 Posts 0 Posters 699 Views
      On 01/11/2015 at 13:32, xxxxxxxx wrote:
      After three days working with Python I'm making good progress, but have hit a wall. Any help or suggestions will be greatly appreciated!
      I'd like to add layers to my shader properties and assign images to them....
      I'm having a difficult time figuring how exactly to do this. I'm Working in R16, so possibly this is not supported in this SDK?
      >     ice[c4d.MATERIAL_USE_TRANSPARENCY] = True                 #enable TRANSPARENCY channel
      >     shdT = c4d.BaseList2D(1011123)                                       #sets Layer  to trans texture
      >     ice[c4d.MATERIAL_TRANSPARENCY_BRIGHTNESS] = .77      #use float to set brightness
      >     ice[c4d.MATERIAL_TRANSPARENCY_REFRACTION] = 1.31     #refraction
      >     ice[c4d.MATERIAL_TRANSPARENCY_SHADER] = shdT
      > #trying to add to texture: layers here
      >     ice.InsertShader(shdT)
      >     ice.Message(c4d.MSG_UPDATE)
      >     ice.Update(True, True)
        On 02/11/2015 at 02:00, xxxxxxxx wrote:
        using the API it is only possible to read the existing layers of a Layer shader but it is not possible to add layers or reorder layers. See also "Adding a layer to the mat color channel"
          On 08/11/2015 at 13:44, xxxxxxxx wrote:
          Thank you Sabastian,
          Do you know if this is resolved in R17?
          Online documentation suggests that there is added support for Layer Shader Layers, and I see the following  function exists:
              LayerShaderLayer.SetParameter()
          Your time is appreciated...
          a)
            On 09/11/2015 at 01:59, xxxxxxxx wrote:
            as described in the documentation, SetParameter() is used to edit the parameters of an existing layer, not to add a new one. This hasn't changed with R17.
              On 09/11/2015 at 11:31, xxxxxxxx wrote:
              Thank you
