    Changing Tag logo
    6 Posts 0 Posters 512 Views
      On 29/10/2015 at 13:44, xxxxxxxx wrote:
      Cinema 4D Version:
      Language(s) :
      Hi everyones,
      There is a way to update or change during my tag execution the logo displayed in object manager?
      Or maybe can I slide the current logo top to bottom or left to right ? In this way i'll have juste one res .tif image file to load and just slide during  execution ?
      Thanks in advance for any help on this.
        On 30/10/2015 at 13:16, xxxxxxxx wrote:
        you need to listen to MSG_GETCUSTOMICON in your tag's Message() function. The structure provided is GetCustomIconData.
        With this you can provide new icons or draw overlays.
          On 31/10/2015 at 02:17, xxxxxxxx wrote:
          Great !! I looking about it and I'll give you a feel back.
          Thanks for all this informations 😉
            On 02/11/2015 at 03:53, xxxxxxxx wrote:
            Hello Andreas. Thank a lot for your informations. But i can not make it work.
            I tried by multiples way but it seems not in my capability yet. Did you have a example in SDK ? Maybe a link with more information about this ?
            last, in any other way maybe a code snippet. I know every ones belong here are very busy...
            I can not make my bitmap slide. I tried with this...
              if (type == MSG_GETCUSTOMICON){
                  GetCustomIconData().dat->x = 32;
            But as you probably know this throw me EXCEPTION ERROR because I guess I don't catch the right object. I Should instantiate something but i can't find it in SDK doc.
            And I can not change my logo neither with this...
                  GetCustomIconData().dat->bmp = AutoBitmap("whatever.tif");
            Same problem, i guess i should instance or catch something and after apply my GetCustomIconData() with additional problem : I not sure on the way to pass it a new data bitmap.
            Thanks on any help on this. Everything else on my plugin seems to work. Soon I'll will asking for a complete review of my code if some are interested (I'm the one most interested!!)
              On 02/11/2015 at 04:38, xxxxxxxx wrote:
              one problem with your code is, that you are creating a new GetCustomIconData structure of your own.
              Instead you should use the one passed with the message (data parameter, which get's cast to the datatype delivered by the message type).
              Here's a small Message() function as an example. Note that _iconBase and _iconOverlayed are two BaseBitmap pointers, that are initialized with two different icons during my startup code.
              Bool MyPlugin::Message(GeListNode* node, Int32 type, void* data)
                switch (type)
                case MSG_GETCUSTOMICON:
                  GetCustomIconData* const gcid = static_cast<GetCustomIconData*>(data); // data pointer interpreted depending on message type
                  if (!gcid || !gcid->dat || !_iconBase || !_iconOverlayed)
                    break;
                  BaseBitmap* const bmp = gcid->dat->bmp;
                  if (bmp)
                    // There's already an icon setup, copy your icon into the existing BaseBitmap
                    GeData d;
                    node->GetParameter(TAG_ICON_OVERLAY, d, DESCFLAGS_GET_0); // TAG_ICON_OVERLAY is a bool parameter in my tag description
                    if (d.GetBool())
                      _iconOverlayed->ScaleIt(bmp, 256, true, false);
                    else
                      _iconBase->ScaleIt(bmp, 256, true, false);
                  else
                    // No icon, yet, provide a new BaseBitmap
                    gcid->dat->bmp = _iconBase;
                  gcid->filled = true; // tell message sender, that you provided a new icon
                  break;
                return SUPER::Message(node, type, data);
              I hope, this helps.
                On 02/11/2015 at 04:50, xxxxxxxx wrote:
                Wahooo ! I'll give you feel back when I have understood this.
                Very interesting. Thanks
