    Code line stops function from continuing on?
    7 Posts 0 Posters 649 Views
      On 22/10/2015 at 08:06, xxxxxxxx wrote:
      Hi Guys,
      def The_Funtion(self, unit) :
      c4d.CallCommand(100004820, 100004820) # Copy
      #---------------| New Doc |-----------------#
              c4d.CallCommand(12094, 12094) # New
      #----| GenerateProjectSettings |----#
              unitScale = c4d.UnitScaleData()
              unitScale.SetUnitScale(1.0, unit)
      bc = c4d.BaseContainer()
      bc[c4d.DOCUMENT_DOCUNIT] = unitScale
      bc[c4d.DOCUMENT_MINTIME] = c4d.BaseTime(self.GetLong(UI_FRAME_FROM_FBX), 30)
              bc[c4d.DOCUMENT_MAXTIME] = c4d.BaseTime(self.GetLong(UI_FRAME_TO_FBX), 30)
      #---|Problem|----------------------------------------------------------------------------------------------------------#
      #--| When this 2 lines Excute, it stops the Function from going to Paste and It do what it suppose to do but don't continue | ----------#
              doc.GetLong(UI_FRAME_TO_FBX, bc[c4d.DOCUMENT_MINTIME].GetMinTime(doc.GetFps()))
              doc.GetLong(UI_FRAME_TO_FBX, bc[c4d.DOCUMENT_MAXTIME].GetMaxTime(doc.GetFps()))
              doc.SetDocumentData(c4d.DOCUMENTSETTINGS_DOCUMENT, bc)
      #--------------- | Paste |-----------------#
              c4d.CallCommand(100004821, 100004821) # Paste
      Help Plz or Tips,
      Ashton
        On 22/10/2015 at 08:49, xxxxxxxx wrote:
        Either
        a) Include an SSCCE, or
        b) be more descriptive (did you check for errors in the console? what did you already try? etc.)
        and please use the
        [*/CODE] tags.
        -N
          On 22/10/2015 at 09:56, xxxxxxxx wrote:
          Hi NiklasR
          This what Console Say:
            File "'SelectedObjectExporter.pyp'", line 1034, in Command
            File "'SelectedObjectExporter.pyp'", line 505, in Bake_Export_Takes_Funtion
          AttributeError: 'c4d.documents.BaseDocument' object has no attribute 'GetLong'
          But if the 2 lines is not there it go through without a problem.
          Help or Tips,
          Ashton
            On 22/10/2015 at 10:37, xxxxxxxx wrote:
            Hi Ashton
            If you search over c4d's pySDK only get
            > BaseContainer. GetLong (Python method, in c4d.BaseContainer)
            > GeDialog. GetLong (Python method, in c4d.gui.GeDialog)
            Seems, you need to retrieve data from bc(or dialog's widget), not doc
              On 22/10/2015 at 10:42, xxxxxxxx wrote:
              Hi NiklasR
              Help or Tips,
              Ashton
              Makes sense, no? Since the lines cause this error.
                On 26/10/2015 at 18:27, xxxxxxxx wrote:
                Hey guys notthing works, i give up, if yall have a answer or another tip plz tell me,  I am already mad about this!, all i want this thing to do is set the Frame time line which is:
                you put your 30 to 40 in
                press export button
                and
                then,
                Set numbers in a new doc project Settings, Which happens!
                and then,
                min to max long that you drag it or set to,
                  in the new project,
                and move on
                lol thats all i ask this thing to do.
                Code i post say it the tells it all.
                Help or Tips,
                Ashton
                  On 27/10/2015 at 01:40, xxxxxxxx wrote:
                  Hi
                  Your code is like small snippet for script manager and few lines are from script-log 😠 (like copy-paste, new, callCommand)
                  maybe need to something like
                  from c4d import gui, documents
                    new = documents.BaseDocument()
                    bc[c4d.DOCUMENT_FPS] = 30
                    bc[c4d.DOCUMENT_MINTIME] = c4d.BaseTime(0) # your data from your gui > c4d.BaseTime(self.GetLong(UI_FRAME_FROM_FBX), 30)
                    bc[c4d.DOCUMENT_MAXTIME] = c4d.BaseTime(50, 30) # your data from your gui > c4d.BaseTime(self.GetLong(UI_FRAME_TO_FBX), 30)
                    new.SetDocumentData(c4d.DOCUMENTSETTINGS_GENERAL, bc)
                    c4d.documents.InsertBaseDocument(new)
