    detecting spline object segment start/end points
    12 Posts 0 Posters 1.2k Views
      On 15/10/2015 at 13:07, xxxxxxxx wrote:
      Hi Ilya,
      +spline
      +null
            pyeffector
            +cloner (clone on object "spline")
                  cube
      the spline can contain many segments "like hair for example, but it is a spline object, segments don't have the same vertex count" , for example:
      a spline which contains 4 segments,
      segment 0: 10 points
      segment 1: 4 points
      segment 2: 13 points
      segment 3: 6 points
      so it is totally random, what I need to know is:
      from the above example: the spline contains 33 points (10 + 4 + 13 + 6) , if I iterate over all points, how to know if this point is the end of a segment?
        On 16/10/2015 at 00:06, xxxxxxxx wrote:
        Hello
        "speed" dirty test for 4 seg. with:
        import math
          op = doc.GetActiveObject()
          if not op: return
          sc = op.GetSegmentCount()
          pnt = op.GetPointCount()
          pntl = []
          for i in xrange(sc) :
              for p in xrange(0, pnt, pow(sc, 3)) :
                  pos = op.GetSplinePoint(p, i)
                  null = c4d.BaseObject(c4d.Onull)
                  null.SetAbsPos(pos)
                  null[c4d.NULLOBJECT_DISPLAY]=13
                  pntl.append(pos)
                  doc.InsertObject(null)
          c4d.EventAdd(c4d.EVENT_0)
          print pntl
        http://imhocloud.com/image/7yAf
          On 16/10/2015 at 03:48, xxxxxxxx wrote:
          thanks Ilya, this helped!
          now the last question:
          how to delete a clone? "inside mograph"
            On 16/10/2015 at 03:58, xxxxxxxx wrote:
            i can not say about "delete"
            But take to look at python sdk - \examples\scenes\ push_apart_effector.c4d
            Per-Edwards showed in this sample how to control visibility of clone
              On 16/10/2015 at 04:02, xxxxxxxx wrote:
              thanks Ilya
                On 16/10/2015 at 09:31, xxxxxxxx wrote:
                Hi guys,
                there's a small bug in Ilya's code, which will produce extra Null objects, if the point count on the spline segments is high enough. And actually there's no need for the pow(sc, 3) construct (which actually gave me some headache, what the script is actually doing...).
                The point is, GetSplinePoint()'s first parameter is a float ranging from 0.0 to 1.0. 0.0 addressing the beginning of the segment, 1.0 then end. Ilya's script misused the power function (step parameter of the xrange) to loop exactly twice (and with higher point counts this failed and the loop was executed more times).
                Simply change the inner loop to:
                for p in xrange(0, 2) :
                p will only be zero or one, the loop is executed only twice and everything's fine.
                Or to answer Mohamed's question directly:
                op.GetSplinePoint(0.0, segmentIndex) # Beginning of segement
                op.GetSplinePoint(1.0, segmentIndex) # End of segement
                Regarding the MoGraph question:
                I don't think, it's possible to remove a clone. So visibility will most likely be your friend.
                  On 16/10/2015 at 09:46, xxxxxxxx wrote:
                  Hello Andreas
                  Thank you that bring the light!
                  woohoo! me was silly, sorry, I get some code from head, different projects from gis(messing with it).
                  GetSplinePoint used as some-how GetPoint
                    On 17/10/2015 at 04:24, xxxxxxxx wrote:
                    Hi Andreas,
                    I knew this 🙂 "about the xrange and the power" , just took the idea to get the last point as needed.
                      On 18/10/2017 at 12:36, xxxxxxxx wrote:
                      I figured out a pretty clean way to do this without using floats
                      def FindSegmentPoints(spline) :
                          scnt = spline.GetSegmentCount()     #get segment count
                          sarr = []                           #array to contain segment start/end dict data
                          cnt = 0                             #var to help us keep track of count position
                          for i in xrange(0, scnt) :                        #iterate through segments
                              c = spline.GetSegment(i)['cnt']              #find current segment count
                              sarr.append({'start':cnt, 'end':cnt+c-1})    #add data to array as dict
                              cnt = cnt + c                                #update count
                          return sarr                         #return array
                      It returns an array where each of the indices is a dict of the start/end points
                      For a rough example, to access the end point of the 3rd segment of 'spline' (a SplineObject) you would do:
                      FindSegmentPoints(spline)[2]['end']
                      I hope this helps 🙂
                      Jenny
                        On 18/10/2017 at 13:40, xxxxxxxx wrote:
                        Here's an additional extension of the previous function.
                        This one can find which segment a point index belongs to, given a SplineObject and the point index
                        #Find segment a point index belongs to
                        def FindSegmentByPoint(spline, index) :      #spline, point index (int)
                            if index > spline.GetPointCount() :      #if index is out of range,
                                print 'index out of range'          #  return -1
                                return -1
                                if cnt < index < (cnt+c-1) :
                                    break
                            return i                                #return segment index
