    How to access Snap Radius
    9 Posts 0 Posters 845 Views
      On 29/09/2015 at 00:11, xxxxxxxx wrote:
      Using Customize Commands you can drag the Snap Radius slider to your interface and set the radius there.
      How to do this (read and write) using Python?
      -Pim
        On 29/09/2015 at 00:56, xxxxxxxx wrote:
        My guess is that it is saved somewhere in the document or world preferences..
        I would also be interested in how we can create such a palette icon widget?
          On 29/09/2015 at 04:49, xxxxxxxx wrote:
          you can read the snap radius quite easily. Just get the settings via GetSnapSettings(). In the returned BaseContainer it's c4d.SNAP_SETTINGS_RADIUS. Like so:
            bcSnap = c4d.modules.snap.GetSnapSettings(doc)
            print bcSnap.GetFloat(c4d.SNAP_SETTINGS_RADIUS)
          There's also SetSnapSettings(). But for some reason I can't get it to work in Python. Either I'm too stupid or there's a bug. As I'm alone this week, I'd like to postpone the research. We'll see, if I find the time.
          One thing, that the docs do not mention (I'll add it there), you need to fire a special event after setting a new radius, so the snap system recognizes the new value.
          This is what works in C++ (here used in a CommandData plugin, needs to include "c4d_snapdata.h") :
          	BaseContainer bc = SnapSettings(doc); // get current settings
          	bc.SetFloat(SNAP_SETTINGS_RADIUS, 42.0);
          	SnapSettings(doc, bc); // set the changed settings
          	SpecialEventAdd(440000118); // ID_SNAPRADIUS is missing in SDK
          @Niklas: Please open a new thread for new topics. In short it is done via a small dialog.
            On 29/09/2015 at 05:42, xxxxxxxx wrote:
            Thanks.
            Could you also update the manual with this information.
            In the link you mention, I do not see SNAP_SETTINGS_RADIUS.
            -Pim
              On 29/09/2015 at 05:46, xxxxxxxx wrote:
              Sure, thanks for the hint.
              As soon as we have solved the SetSnapSettings() issue, we'll update the Python docs on this topic.
                On 30/09/2015 at 02:11, xxxxxxxx wrote:
                Hi Andreas,
                Sorry, for me it is not working.
                I can read, but not write the snap radius.
                Here the code converted to Python.
                from c4d import gui
                    bc = c4d.modules.snap.GetSnapSettings(doc)     #get current settings
                    print bc.GetFloat(c4d.SNAP_SETTINGS_RADIUS)
                    bc.SetFloat(c4d.SNAP_SETTINGS_RADIUS, 25.0)
                    c4d.modules.snap.SetSnapSettings(doc, bc)    #set the changed settings
                    c4d.SpecialEventAdd(440000118)    #ID_SNAPRADIUS is missing in SDK
                -Pim
                  On 30/09/2015 at 02:13, xxxxxxxx wrote:
                  Hi Pim,
                  did you read my post? That's what I wrote, I couldn't get it to work in Python, either. That's the reason I posted C++ code to the Python forum. We need to investigate... sorry
                    On 30/09/2015 at 05:48, xxxxxxxx wrote:
                    Sorry, I guess I did not fully understand until I tried it myself.
                    Now I see what you mean.
                    "There's also SetSnapSettings(). But for some reason I can't get it to work in Python".
                    SetSnapSettings is a python command, which you do not use in your c++ code.
                    So, c++ is working, but python is not working?
                    -Pim
                      On 30/09/2015 at 05:51, xxxxxxxx wrote:
                      Yes, in C++ it's working. And Python's SetSnapSettings() and GetSnapSettings() functions are just called SnapSettings(), overloaded for read and write.
