    Different initGLImage for each object
    3 Posts 0 Posters 335 Views
      On 22/09/2015 at 06:28, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Hello.
      I have created a material plugin and whenever i assign that material to an object the initGLImage runs to calcualte the bitmap that will be used in the viewport.
      I want different image based on each object.
      Can i do that somehow ?
      As i see, even though i assign the same material in multiple objects, initGLImage runs only once.
      Thank you.
        On 22/09/2015 at 11:45, xxxxxxxx wrote:
        I think it is doable.
        in simplematerial example, check for MATPREVIEW_MODIFY_CACHE_SCENE
        depending on the scene, you can set a member with the required data.
        make sure to copy that member "CopyTo function"
        using that member, you can change the initGLImage behavior.
          On 23/09/2015 at 02:11, xxxxxxxx wrote:
          don't confuse the material preview image of the material editor with the OpenGL preview image. The OpenGL preview image is used to create a preview of a complex material in the interactive viewport. This bitmap is stored with the material and is only created for the material, not for each material/object combination.
