    R17's New Motion Blur SDK
    12 Posts 0 Posters 1.3k Views
      On 16/09/2015 at 07:42, xxxxxxxx wrote:
      we are aware, we need to deliver additional information on the motion blur changes. Unfortunately we had no time to learn it ourselves and the responsible developer is on vacation. We'll return to this topic as soon as possible.
        On 16/09/2015 at 07:58, xxxxxxxx wrote:
        Thanks for the info! I look forward to learning more.
          On 16/11/2015 at 14:47, xxxxxxxx wrote:
          Where can we get any additional information for this topic? I need to add motion blur support for vertex speed vectors.
            On 16/11/2015 at 15:55, xxxxxxxx wrote:
            I'm digging the some commands to discover the secrets. Why i can't catch non-null pointers for RayMotionObject? Should i set somethings to produce motion blur as putting a Motion Blur Tag?
            for(Int32 j=0;j<vd->GetObjCount();j++)
                const RayObject \*rop=vd->GetObj(j);
                const RayMotionObject \*motOp = vd->GetMotionObject((RayObject\* )rop);
                info("Rayobj:"+rop->link->GetName()+"  motOp:"+PS2(motOp));
              On 17/11/2015 at 08:51, xxxxxxxx wrote:
              the new Motion Blur API can only be used in conjunction with the Physical Renderer and only if Motion Blur got enabled.
                On 17/11/2015 at 09:29, xxxxxxxx wrote:
                Hi Andreas,
                Wow how crazy idea to support third party renderers. So what's the way for us? How can we support Real Flow meshes or similar objects?
                Best regards,
                Ahmet
                  On 17/11/2015 at 09:30, xxxxxxxx wrote:
                  Hey, I'm only the messenger!
                    On 17/11/2015 at 09:32, xxxxxxxx wrote:
                    Ok i understand, but any way or suggestion to provide this support? Who can help for this?
                      On 17/11/2015 at 09:36, xxxxxxxx wrote:
                      Here's some info Sebastian just gave me:
                      So in your VideoPostData plugin you can get the motion delta values stored with RayObjects and the RayCamera. To get deformed geometry you can use VolumeData::TranslatePolygon to get the points of a given polygon for the previous frame. To access these values one must return the flags VIDEOPOSTINFO_REQUEST_MOTIONMATRIX and VIDEOPOSTINFO_REQUEST_MOTIONGEOMETRY in the VideoPost's GetRenderInfo() function.
                        This is great start point to work. One more question; Does this supports the unconstant vertex counts?
