    cdl64 not loaded
    8 Posts 0 Posters 634 Views
      On 14/09/2015 at 14:53, xxxxxxxx wrote:
      Cinema 4D Version:   R16
      Hello!
      I have created a plugin that runs in my system as it supposed to (using Visual Studio 2013).
      It creates a folder MyPlugin along with the corresponding menu item.
      Everything works fine.
      Sometimes though, when i transfer the plugin folder to other PCs, it is not loaded in Cinema4D.
      Even when i try to run Cinema4D using visual studio (via cinema4dSDK) i get the messages:
      'CINEMA 4D.exe' (Win32) : Loaded '<path>/my_plugin.cdl64'. Cannot find or open the PDB file.
      'CINEMA 4D.exe' (Win32) : Unloaded '<path>/my_plugin.cdl64'
      Why does it unload the plugin?
      Thank you.
        On 15/09/2015 at 03:43, xxxxxxxx wrote:
        you need to recompile it, I guess you are doing it in debug mode, in release mode you won't encounter this problem.
          On 15/09/2015 at 04:34, xxxxxxxx wrote:
          Hello.
          I build it in release mode and then i install it in different PCs.
          Thnx.
            On 15/09/2015 at 05:53, xxxxxxxx wrote:
            my first bet would be the version of Cinema 4D (actually the API_VERSION). If the plugin id build on a higher version than the version trying to load the plugin, it will fail.
            Usually you can expect your plugins to be upward compatible. For example, I still have plugins running in R17, that have been built against R13. The other way around won't work.
            So, this would be the first thing to check.
              On 15/09/2015 at 06:24, xxxxxxxx wrote:
              Hello !
              The plugin is built using the R16 Api.
              It also runs in R15 and R17 but it doesnt in R16.
                On 15/09/2015 at 06:34, xxxxxxxx wrote:
                Please check also the minor version. For example there was a problem[URL-REMOVED] within R16, which made it necessary to bump the API_VERSION during R16.
                  On 16/09/2015 at 23:54, xxxxxxxx wrote:
                  I have the same issue.
                  I compiled on 16.59 and it runs.
                  It also runs on 16.050 (Build RB131856).
                  I will check with the customer which version he runs.
                  For what versions will it fail?
                    On 17/09/2015 at 00:33, xxxxxxxx wrote:
                    Hello.
                    Thank you very much for your answer.
                    Updating Cinema4D version solves the problem.
                    thnx.
