    Compiling COFFEE files in R8
    3 Posts 0 Posters 685 Views
      On 05/02/2003 at 17:53, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Hi there,
      Newbie here - just starting with COFFEE.  I have downloaded the compiler.zip, unzipped into the Plugins directory, and tried to compile a simple .cof into a .cob inside of R8.  It returns this error:
      COFFEE ERROR!
      (2) Not enough memory
      Am I missing something in the file required to compile properly?   It's a simple "Hello World" to start.
      Robert Templeton
        On 06/02/2003 at 04:06, xxxxxxxx wrote:
        I cannot confirm this. The C.O.F.F.E.E. compiler from the 6.302 C.O.F.F.E.E. SDK seems to work just fine in C4D 8.012. Please see if you can compile any of the example files first.
          On 06/02/2003 at 08:00, xxxxxxxx wrote:
          Figured it out.  Seems that the file needed to be inside a folder within the Plugin directory and have a Plugin ID set (test ID).  Then it compiled without problems.
