    If clone is inside falloff - freeze position. PyMo
    5 Posts 0 Posters 568 Views
      On 09/09/2015 at 05:39, xxxxxxxx wrote:
      Hello!
      Can anybody point me in the right direction to what I'm doing wrong here?
      I can see how many clones are inside the falloff and access their index, but can't set/fix their position
      whilst they are inside the falloff region 😞
      Here is my code so far:
      __________________________
      from c4d.modules import mograph as mo
      md = mo.GeGetMoData(op)
          if md==None: return False
          cnt = md.GetCount()
          marr = md.GetArray(c4d.MODATA_MATRIX)
          fall = md.GetFalloffs()
          carr = md.GetArray(c4d.MODATA_COLOR)
          MoColAr = md.GetArray(c4d.MODATA_COLOR)
          l = [] # Empty list to store falloff clones
          for i in xrange(0, cnt) :
              if fall == 1:
      _            l2 = i_
      _            l.append(l2)_
      _    _
      _    print "Number of clones inside fall off ", len(l)_
      _    #print "Falloff cloner index values: ", l   _
      _    _
      _    _
      _    for i in xrange (len(l)) :_
      _        print marr ___
      _ _        marr = marr _____
      _ _ _        #MoColAr = c4d.Vector(0)
      __
      _ _ _    ___
      _ _ _    md.SetArray(c4d.MODATA_Matrix, marr, True)___
      _ _ _    #md.SetArray(c4d.MODATA_COLOR, MoColAr, True)___
      _ _ _    ___
      _ _ _    #b = "Number of clones inside falloff = " + str(len(l))___
      _ _ _    #c4d.StatusSetText(b)___
      _ _ _   ___
      _ _ _    ___
      _ _ _    return True___
      _ _ __________________________________
      _ _ Any help on this would be much appreciated! -  Thank you in advance!__
        On 09/09/2015 at 06:29, xxxxxxxx wrote:
        Hi
        Some mods and fix typos mad and seems, all work - video demo
        i use
        marr _.off = c4d.Vector(0)_
        _to freeze position
          cnt = md.GetCount()
              if fall[i] > 0:
                  l2 = i
                  l.append(l2)
              print marr
              marr[i].off = c4d.Vector(0)
              md.SetArray(c4d.MODATA_MATRIX, marr, True)
        _
          On 09/09/2015 at 12:50, xxxxxxxx wrote:
          Thanks for your help Ilya, really appreciate it!
          The issue I'm having is that i want to freeze the clones in its current position.... It seems trickier than it sounds! 😢
          Appending marr.off and passing back doesn't work as the marr.off value is constantly calculated.
           I'm trying tuples without any luck!
          Thanks again! If you have any ideas let me know!
            On 15/09/2015 at 07:07, xxxxxxxx wrote:
            I played around with this. Here's what I came up with:
            # two global arrays
            fixed = [] # stores for each clone, if it is currently fixed
            pos = []   # stores fixed position for each clone
                cnt = md.GetCount()
                # extend and initialize list to match number of clones, if needed
                if len(fixed) < cnt:
                    for i in xrange(len(fixed), cnt) :
                        fixed.extend([False])
                        pos.extend([c4d.Vector(0.0, 0.0, 0.0)])
                # walk all clones
                    if fall[(cnt - 1) - i] > 0.0: # NOTE: content of the falloffs array is reverse
                        # Clone is inside falloff
                        if fixed[i] == False: # if not yet fixed, we store the position and mark it fixed
                            pos[i] = marr[i].off
                            fixed[i] = True
                        marr[i].off = pos[i]
                        # Clone is outside falloff, so we release it (do not touch marr[i].off)
                        fixed[i] = False
                # finally don't forget to update the MoData with our changed matrices
            Note 1: GetFalloffs() returns the results in the inverse order compared with the other MoData arrays. I'm still investigating, what's the reason for this behavior (maybe to have same behavior as good old COFFEE...). As soon as I have found out, I'll add a note to the docs.
            Note 2: For simplicity I used global arrays in my example. Of course you may also store the values in the object's or effectors BaseContainer (using a valid PluginID) or you could add User Data to store the values.
            Hope this helps.
              On 15/09/2015 at 07:22, xxxxxxxx wrote:
              Thank you Andreas, great work! I didn't think to include the lists outside of the main function, and haven't used .extend before. I'm going to make sure I fully understand this - but it's working great!
              Thank you once again,
              Simon
