    Creating a Selected Object Exporter Plugin for C4D
    19 Posts 0 Posters 2.7k Views
      On 16/09/2015 at 07:30, xxxxxxxx wrote:
      before trying to answer your question, one request from my side:
      Please do not double post into several threads. Besides cluttering the forums, this could lead to several people investing time into your request in parallel.
      As I wasn't exactly sure, what you were asking for, I basically merged all information given in this thread into a single script.
      Of course you'd also be free to mix the code from the Script Log with "normal" Python scripts. Assuming, that you want to call Sebastian's script on the "# PS_M_id" line, you could use Sebastian's code in there directly.
      If you need to separate the functionality, I think it would be best to use Command plugins instead of scripts (as these will have a constant plugin ID).
      Enough options, here's my script, it's basically the workflow suggested by Eclektric earlier:
      from c4d import gui
      # Export all selected objects to Collada
          objs = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_CHILDREN)
          if objs == None:
          # Get a fresh, temporary document with only the selected objects
          docTemp = c4d.documents.IsolateObjects(doc, objs)
          if docTemp == None:
          # Set project scale
          unitScale = c4d.UnitScaleData()
          unitScale.SetUnitScale(1.0, c4d.DOCUMENT_UNIT_M)
          bc = c4d.BaseContainer()
          bc[c4d.DOCUMENT_DOCUNIT] = unitScale
          docTemp.SetDocumentData(c4d. DOCUMENTSETTINGS_DOCUMENT, bc)
          # Export the temporary document as Collada file
          # Collada im-/exporter IDs:
          # ID_COLLADA14_IMPORT 1022315
          # ID_COLLADA14_EXPORT 1022316
          # ID_COLLADA15_IMPORT 1025754
          # ID_COLLADA15_EXPORT 1025755
          if c4d.documents.SaveDocument(docTemp, "test.dae", c4d.SAVEDOCUMENTFLAGS_0, 1022316) == False:
              print "Save error"
          # In a previous version I used the KillDocument() call below.
          # It does no harm, but it is redundant, as docTemp never was inserted.
          # Throw away the temporary document
          # c4d.documents.KillDocument(docTemp)
        On 16/09/2015 at 10:54, xxxxxxxx wrote:
        hi Andreas Block and sorry again , hey try it but it dont work I am now lost now but take a look at where i put it.
        class SelectedObjectExporterDialog(c4d.gui.GeDialog) : #<-------Main Dialog for the Plugin----#
            #_____ Interface Layout______________________________________________________#
            LOGO = BANNER()
        def CreateLayout(self) :
        self.SetTitle("Selected Object Exporter v0.1")   # <-------------My Title for the MAIN Dialog------
        #The Menu for top part of Interface_____(About)-(Check for Updates)_________#
                self.MenuFlushAll()
        self.MenuSubBegin("About")
                self.MenuAddString(ABOUT["id"], ABOUT["name"])
                self.MenuSubEnd()
                self.MenuFinished()
        self.MenuSubBegin("Check for Updates")
                self.MenuAddString(Check_for_Updates["id"], Check_for_Updates["name"])
                self.MenuSubEnd()
                self.MenuFinished()
        #---This is were Your Plugin Image Group Go!------------------------------------------------------------------>
                self.GroupBegin(0, c4d.BFH_CENTER | c4d.BFV_CENTER, cols=1)
                self.GroupBorderNoTitle(c4d.BORDER_NONE)
                self.GroupBorderSpace(0, 0, 0, 0)
                self.AddUserArea(1, c4d.BFV_CENTER | c4d.BFV_CENTER)
                self.AttachUserArea(self.LOGO, 1)
                self.GroupEnd()
        self.AddSeparatorH(200, flags=c4d.BFH_SCALEFIT)
        self.AddStaticText(0, c4d.BFH_CENTER, 0, 0, "|<| Welcome to SELECTED OBJECT EXPORTER |>|", 0) # <-------------My title ------
        self.GroupBegin(20007, c4d.BFH_FIT | c4d.BFH_SCALEFIT, 1, 0, "")     # <------------|
                self.AddSeparatorH(200, flags=c4d.BFH_SCALEFIT)                                   # Adding Separator lol ,thats how I put it. AND I use it Aot.
                self.GroupEnd()
                #_____PART OF EXPORT Tab __________Quick Selected Exporter_________________________________________________#
        self.GroupBegin(20078, c4d.BFH_SCALEFIT | c4d.BFV_BOTTOM, 1, 0, "")
        self.Only_Obj = self.AddCheckbox(Selected_1, c4d.BFH_LEFT, 250, 0, "Selected Object Only")
                self.SetBool(Selected_1, True)
        self.GroupBegin(20078, c4d.BFH_SCALEFIT | c4d.BFH_CENTER | c4d.BFV_BOTTOM, 2, 0, "| Select Format |")
                self.GroupBorder(c4d.BORDER_GROUP_IN)
        self.AddStaticText(0, c4d.BFH_LEFT, 100, 0, "   FORMAT :")
        self.format_list = self.AddComboBox(Exporter_Button, c4d.BFH_SCALEFIT, 46, 0, False) # <----- DROP MENU using a ComboBox and in the list that is (AddChild) .
                self.AddChild(Exporter_Button, DAE_1_4, 'COLLADA 1.4 (*.dae)')
                self.AddChild(Exporter_Button, FBX_ALL, 'FBX (*.fbx)')
                self.AddChild(Exporter_Button, W_Obj, 'Wavefront (*.obj)')
                self.AddChild(Exporter_Button, thee_Ds, '3D Studio (*.3ds)')
                self.AddChild(Exporter_Button, Direct_3D, 'Direct 3D (*.x)')
                self.AddChild(Exporter_Button, Alembic_abc, 'Alembic (*.abc)')
                self.AddChild(Exporter_Button, COLLADA_15, 'COLLADA 1.5 (*.dae)')
                self.AddChild(Exporter_Button, Illustrator_AI, 'Illustrator (*.ai)')
                self.AddChild(Exporter_Button, STL_stl, 'STL (*.stl)')
                self.AddChild(Exporter_Button, Dxf_DXF, 'DXF (*.dxf)')
                self.AddChild(Exporter_Button, 123349, '-----------------------')
                self.AddChild(Exporter_Button, 123346, 'MDL (*.MDL) Flight Sim Model')
        self.GroupEnd()
        self.AddSeparatorH(250, flags=c4d.BFH_SCALEFIT)
        self.GroupBegin(20078, c4d.BFH_SCALEFIT | c4d.BFV_BOTTOM, 2, 0, "")
                self.AddStaticText(0, c4d.BFH_LEFT, 240, 0, "  Model Project Scale. . . . . . .  . . . .  . .")
                self.format_list2 = self.AddComboBox(Exporter_Button2, c4d.BFH_SCALEFIT, 50, 0, False)
                self.AddChild(Exporter_Button2, ID_CM, 'Centimeters')
                self.AddChild(Exporter_Button2, ID_M, 'Meters')
                self.AddChild(Exporter_Button2, 10034, 'Kilometers')
                self.AddChild(Exporter_Button2, 10034, 'Millimeters')
                self.AddChild(Exporter_Button2, 10034, 'Miles')
                self.AddChild(Exporter_Button2, 10034, 'Yards')
                self.AddChild(Exporter_Button2, 10034, 'Feet')
                self.AddChild(Exporter_Button2, 10034, 'Inches')
                self.GroupEnd()
        self.AddButton(UI_BT_Export, c4d.BFH_SCALEFIT | c4d.BFV_BOTTOM , 100, 20, "EXPORT MODEL >>>")
        self.GroupSpace(200, 5)
                self.GroupEnd()
        self.GroupEnd()
                self.AddStaticText(0, c4d.BFH_CENTER, 0, 10, "<<<<[-A Part of C4D|2|light SIM SDK-]>>>>", 0)
                self.AddButton(ID_Updates_BT, c4d.BFH_RIGHT, initw=180, name="Check for Updates")
        #self.AddStaticText(0, c4d.BFH_CENTER, 0, 10, "<<<-------------<[-QuantumDrop Studios-Copyrights 2015-]>----------->>>", 0) # for When Its Ready to go!
        self.GroupEnd()
        if self.readSettings() == False:
                    self.SetLong(self.format_list, Exporter_Button)
                    self.SetLong(self.format_list2, Exporter_Button2)
            ############### End  of Layout #################################
            ####### The Set State of the Layout Interface#######________________________#
            def InitValues(self) :
                self.SetLong(Exporter_Button, Exporter_Button) #Sets the combobox to the first option when plugin opens
                self.SetLong(Exporter_Button2, ID_CM)
                self.UpdateDlg(self.GetLong(Exporter_Button))
                self.UpdateDlg(self.GetLong(Exporter_Button2))
        #_E.X.P.0.R.T__F.O.R.M.A.T.S________________________________________________________#
            ###-FORMATS FUNCTION For Commands -#######################
        #####_M.E.T.E.R.S_(ID_M)#####
            def DAE_1_4_Format_M(self) :
                if objs == None:
                if docTemp == None:
        # Set project scale
                #c4d.CallCommand(100004821, 100004821) # Paste
                #c4d.CallCommand(60000, 5) # Export Filter for DAE 1.4 in R16 and r17
            def Three_DS_Format_M(self) :
                c4d.CallCommand(100004820, 100004820) # Copy
                c4d.CallCommand(12094, 12094) # New
                c4d.CallCommand(600000032, 600000032) # PS_M_id
                c4d.CallCommand(60000, 11) # Export Filter 3ds
                c4d.CallCommand(12664, 12664) # Close
            def FBX_Format_M(self) :
                c4d.CallCommand(60000, 9) # Export Filter
            def OBJ_Format_M(self) :
                c4d.CallCommand(60000, 14) # Export Filter - obj
            ###########_C.E.N.T.I.M.E.T.E.R.S_(ID_CM)###################
            def DAE_1_4_Format_CM(self) :
                c4d.CallCommand(600000031, 600000031) # PS_CM_id[10601]
                self.Close()
            def Three_DS_Format_CM(self) :
            def FBX_Format_CM(self) :
            def OBJ_Format_CM(self) :
        #_T.H.E__C.O.M.M.A.N.D.S__F.U.N.C.T.I.O.N.S___________________________________________________________________________________________________________________________#
            def Command (self, id, msg) :
                if id == UI_BT_Export:
                    if self.GetLong(10010)==ID_M: #<-------| if meters Check in the ComboxBox then excute the formats in the following of Meters List|
                        if self.GetLong(10004)==DAE_1_4:
                            self.DAE_1_4_Format_M()
        if self.GetLong(10004)==thee_Ds:
                            self.Three_DS_Format_M()
        if self.GetLong(10004)==FBX_ALL:
                            self.FBX_Format_M()
        if self.GetLong(10004)==W_Obj:
                            self.OBJ_Format_M()
        if self.GetLong(10004)==123346:
                            gui.MessageDialog('Sorry! \n MDL file format is not Supported at this time, \n this feature will be available in the future. \n This apart of C4DtoFlightSim SDK')
                        elif self.GetLong(10004)==Exporter_Button:
                            gui.MessageDialog('Error 299 :Please Select A Export Format\nin the drop down list\nand have a good day!')
                            print "Please Select A Export Format"
                    elif self.GetLong(10010)==ID_CM:
                            self.DAE_1_4_Format_CM()
                            self.Three_DS_Format_CM()
                            self.FBX_Format_CM()
                            self.OBJ_Format_CM()
                            gui.MessageDialog('Please Select A Export Format \n And have a good day!')
                elif id==ABOUT["id"]:
                    self.About()
                elif id==Check_for_Updates["id"]:
                    self.Check_for_Updates()
            #____END OF Comands____#
        #_Addons Menu on top =(About, Check for Updates)
                #_About In ifo ________#
            def About(self) :
                # MENU ITEM - About
                # Open a messagebox with about info
                gui.MessageDialog("This is the Selected Object Exporter from FlightSim SDK\nfor Cinema 4D Users\n---------------\nThis Plugin let you Export the Selected Object\nfrom your scene.\n---------------\nCreated By Ashton Rolle,Creswell Gould and Beris Omerović\nEmail Us: ( [email protected])\n---------------\nQuantumDrop Studios-Copyrights 2015", c4d.GEMB_OK)
                #_CHeck for Updates____#
            def Check_for_Updates(self) :
                self.Dialog2 = UpdateDialog()
                self.Dialog2.Open(dlgtype=c4d.DLG_TYPE_ASYNC, defaultw=400, defaulth=150, xpos=-1, ypos=-1)
        #____The Plugin Info and Plugin Register_______#
        class SelectedObjectExporter(c4d.plugins.CommandData) :
        dialog = None
        def Init(self, op) :
        def Message(self, type, data) :
        def Execute(self, doc) :
                if self.dialog is None:
                    self.dialog = SelectedObjectExporterDialog()
                return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=320, defaulth=200)
            fn = os.path.join(dir, "res/Icons", "Icon_3.png")
            bmp.InitWith(fn)
            print "Selected Object Exporter loaded."
            result = plugins.RegisterCommandPlugin(PLUGIN_ID, "SelectedObjectExporter", 0, bmp, "SelectedObjectExporter", SelectedObjectExporter())
          On 17/09/2015 at 02:14, xxxxxxxx wrote:
          please don't get this wrong, but I won't start debugging your code without a real question or error description. Also it looks like you completely ignored the code I posted.
          Always remember, we have to support a lot of developers (not only the ones present in this forums). Please help us to help you.
            On 17/09/2015 at 18:56, xxxxxxxx wrote:
            Sorry bro it not that, your code works! its just, it does not work when i put the code of the ( def DAE_1_4_Format_M(self) : ) thats the thing and i like your code lol , and that why i say what if i wanted to call out to a .py file  in the res folder and excute it,  than script folder and it would be to still on how to do this Andreas
            It would be cool and i mix script up to take a look : I can give it a name and it will export
                if objs == None:
                if docTemp == None:
                # Set project scale
                # Get Alembic export plugin, 1028082 is its ID
                plug = plugins.FindPlugin(1022316, c4d.PLUGINTYPE_SCENESAVER)
                if plug is None:
                # Get a path to save the exported file
                filePath = storage.LoadDialog(title="Save File for COLLADA 1.4 Export", flags=c4d.FILESELECT_SAVE, force_suffix="dae")
                if filePath is None:
                    # Finally export the document
                if documents.SaveDocument(docTemp, filePath, c4d.SAVEDOCUMENTFLAGS_EXPORTDIALOG, 1022316) :
                    print "Document successfully exported to:"
                    print filePath
                    print "Export failed!"
            But the only thing is getting it to work with my code i had setup for , thats all.
            but Sorry Again Andreas
              On 25/09/2015 at 10:21, xxxxxxxx wrote:
              For everybody else reading this thread:
              Ashton sent me his code. And it turned out, I didn't understand (sorry for that, Ashton) his question correctly.
              Instead of calling the scripts he had prepared, he wanted to use a direct implementation. All he was missing, was to get the active document (c4d.documents.GetActiveDocument()) in order to get the code I posted working.
              Again: Sorry, for being so slow-witted, Ashton.
                On 26/09/2015 at 08:16, xxxxxxxx wrote:
                It's ok , but WERE YOU PUT IT CAUSE I SO LOST!
                sorry but can u message me on that Andreas!
                        if objs == None:
                        if docTemp == None:
                # Set project scale
                        filePath = storage.LoadDialog(title="Save File for COLLADA Export", flags=c4d.FILESELECT_SAVE, force_suffix="dae")
                Ashton
                  On 26/09/2015 at 13:09, xxxxxxxx wrote:
                  Sorry, I wanted to send it via mail, but I messed it up. I just sent another mail.
                  What's the reason for posting code again?
                    On 26/09/2015 at 14:27, xxxxxxxx wrote:
                    ok, he wanna  something direct, why not to use something such http://pycollada.readthedocs.org/en/v0.4/intro.html or autodesk fbx20xx_x_fbxpythonsdk_os
                      On 26/09/2015 at 15:07, xxxxxxxx wrote:
                      Thanks for the tips for Andreas and I will have the plugin up and run in a week thanks and i will send you a copy bro.
                        On 29/09/2015 at 10:04, xxxxxxxx wrote:
                        Thanks for Everyone Help guys on the Forum! everything is working Check this video out!
                        and this were you can get the plugin too!
                        Selected Object Exporter Plugin for Cinema 4D (Beta Ready)
                        Enjoy,Cheers,
                        Ashton
