    Calling "Bake" Button in the Bake Texture Tag ?
    3 Posts 0 Posters 366 Views
      On 04/09/2015 at 11:16, xxxxxxxx wrote:
      Hello.
      Im trying to start the baking of a texture using python.
      But i cant seems to get it working correcty.
      Does anyone know how i can start the bakeing prosess ?
      Here is a sniped of my code.
      if object != None:
        # only do it for polygon objects.
        if object.GetType() == 5100:
            tags = object.GetTags()
            for tag in tags:
                # Check if its a bake textuure tag and start the bake..
                if tag.GetType() == 5616:
                    c4d.CallButton(tag, c4d.BAKETEXTURE_BAKE)
      What do i need to do??
        On 07/09/2015 at 04:50, xxxxxxxx wrote:
        not sure what is going wrong for you.
        Your code looks ok and I quickly tested it here without problems in Script Manager:
            obj = doc.GetActiveObject()
            if obj == None:
            tag = obj.GetTag(c4d.Tbaketexture)
            if tag == None:
        A small side note, I'd recommend to use the constants provided by the SDK instead of hard coded values.
        Where are you using this code? In a script, a plugin (if so, which type and where), Interaction tag, Python tag, Python Xpresso node or Sketch material?
          On 09/09/2015 at 09:44, xxxxxxxx wrote:
          lol all you need is this V pop up ,
          Download Cinema 4D_Studio_Pro_Setup_2015 just Search for it
          and go in Cinema 4D_Studio_Pro_Setup_2015\NEW! Scheme Editor Colors folder\prefs
          copy c4d_M_GLOBAL_POPUP and paste it in your prefs folder
          start c4d
          and press V
          you have a list call Baking Tools!
          Cheers bro!
          Andreas edited: Removed link!
          And readded link, after checking the content. Sorry, for the hazzle.
