    Strange behavior of py 2.7 in r17
    General Discussion
    0
    1.8k
    • H
      On 03/09/2015 at 01:49, xxxxxxxx wrote:
      Hello
      I use Python.win64.framework as main environment for 2.7... > any install command executed in root: pip install numpy and etc.
      if i use windows command line and check module:
      _python -c "import numpy; print numpy.__version__, numpy.__file__"
      _ or execute scripts >> all are ok _
      _
      if in c4d: some libs are not loaded, numerous errors and bla-bla ... i read in net about virtual environment _(has c4d r17 such?!) 😠
      _ i several times reinstall modules: numpy, scipy, cython. After such clean-up and reinstall, modules work over session. Next session will not _
      _Modules are for py 2.7
      Test at windows os - win 8 x64 _
      wheels of modules:
      Cython-0.22.1-cp27-none-win_amd64.whl
      numpy-1.10.0b1+mkl-cp27-none-win_amd64.whl
      scipy-0.16.0-cp27-none-win_amd64.whl
      _ Pillow-2.9.0-cp27-none-win_amd64.whl - for scipy
      • H
        On 03/09/2015 at 03:35, xxxxxxxx wrote:
        Caught such minutes ago, at such simple init:
        import numpy as np
          x = np.array([1, 2, 3])
          print x
        got in c4d console:
          File "'scriptmanager'", line 2, in <module>
          File "J:\maxon\C4DR17D\resource\modules\python\Python.win64.framework\lib\site-packages\numpy\__init__.py", line 195, in <module>
          from . import add_newdocs
          File "J:\maxon\C4DR17D\resource\modules\python\Python.win64.framework\lib\site-packages\numpy\add_newdocs.py", line 13, in <module>
          from numpy.lib import add_newdoc
          File "J:\maxon\C4DR17D\resource\modules\python\Python.win64.framework\lib\site-packages\numpy\lib\__init__.py", line 8, in <module>
          from .type_check import *
          File "J:\maxon\C4DR17D\resource\modules\python\Python.win64.framework\lib\site-packages\numpy\lib	ype_check.py", line 11, in <module>
          import numpy.core.numeric as _nx
          File "J:\maxon\C4DR17D\resource\modules\python\Python.win64.framework\lib\site-packages\numpy\core\__init__.py", line 14, in <module>
          from . import multiarray
        ImportError: DLL load failed: ....
        Result in r16:
        [1 2 3]
        • H
          On 03/09/2015 at 10:34, xxxxxxxx wrote:
          Does it possible if something be wrong with vars PYTHONPATH /PYTHONHOME inside c4d?
          I test examples for modules in root of Python.win64.framework - all are work _
          _
          • H
            On 04/09/2015 at 02:32, xxxxxxxx wrote:
            Hi Ilya,
            as stated in the announcement[URL-REMOVED] of the Python integration change, Python C-modules need to be recompiled with VS2012 SP4 and/or Xcode (latest version). From the "ImportError: DLL load failed" I'm guessing, this might be the issue here.
            • H
              On 04/09/2015 at 03:36, xxxxxxxx wrote:
              Hi Ilya,
              Awesome finding! Thank you... I put this reminder in front of me as billboard
              I download compiled builds from http://www.lfd.uci.edu/~gohlke/pythonlibs
              They have:
              Many binaries depend on NumPy-1.9+MKL and the Microsoft Visual C++ 2008 (x64, x86, and SP1 for CPython 2.6 and 2.7 ), Visual C++ 2010 (x64, x86, for CPython 3.3 and 3.4), or the Windows 10 Universal C Runtime redistributable packages.
              Probably they using http://www.microsoft.com/en-us/download/details.aspx?id=44266
              And recompiled numpy, it works...
              • H
                On 06/09/2015 at 06:36, xxxxxxxx wrote:
                Alternative(or even one of standard) scheme or solution to compile or using "old dll" * module - use of anaconda mingwpy or modules base at mingwpy from anaconda, mingw64 compiler.
                i compile numpy and several c-extensions, linking and etc. to vs2012.
                I only could not to compile scipy for py.27_vc11, got numerous errors.
                Ok i make test with mingwpy, compile and it works
                * - used msvcr90.dll
