    AM dialogs
    6 Posts 0 Posters 801 Views
      On 05/02/2003 at 14:24, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Platform:    Mac  ;
      What must I do to update one tag I did for version 7 and had a dialog to make the dialog show in the new AM?
      Easy? Hard? How?
      Thank you in advance.
      Rui Batista
        On 05/02/2003 at 16:04, xxxxxxxx wrote:
        not possible in COFFEE yet.
        Samir
          On 06/02/2003 at 01:30, xxxxxxxx wrote:
          Damn!! 😞
          COFFEE really needs an update! The documentation of COFFEE is still from 6.xxx 😞
          Rui Batista
            On 06/02/2003 at 01:55, xxxxxxxx wrote:
            Has coffee itself changed since version 6? I don't think it has.
            I get the impression that Coffee is not going to be updated.
            I think the idea is that if you are writing a complex plugin then you should do it with the C++ API (which is pretty extensive and well written, BTW). If you are writing something fairly simple then you are expected to use Espresso instead.
            I've not had a chance to have anything more than a very cursory look at Espresso, so I don't know how useful it really is in this regard at the moment.
            Is there anything that Espresso can do that Coffee can't (hopefully yes), and vice versa (hopefully no)?
              On 06/02/2003 at 02:55, xxxxxxxx wrote:
              XPresso can do lots of things, but is designed as an animation tool, not really something for plugins, COFFEE should be for adding simple editor extensions and some animation control, C++ is for "real" plugins, shaders etc. you can do shaders in COFFEE, but you will get a speed penalty for any COFFEE based plugin. COFFEE is in need of some work, and can do things XPresso can't (such as modify objects data). I'm sure COFFEE won't be forgotten, an easy to use scripting system is important, COFFEE was part way to this. Although it didn't change for XL7, there wouldn't be much extra it could have been given, however, for R8 there is so much new work in the SDK that makes COFFEE really show up as not updated, I'm sure MAXON will deal with this.
                On 06/02/2003 at 14:47, xxxxxxxx wrote:
                I really hope so. I'm not willing to invest on a compiler. I love to program but I'm not a true programmer. That's why I want to be still be able to develop my tools without the need of a compiler.
                I'm eagerly waiting for a COFFEE update 🙂
                Rui Batista
