    Create tex Folder in project directory
    4 Posts 0 Posters 525 Views
      On 31/08/2015 at 02:48, xxxxxxxx wrote:
      Cinema 4D Version:   R16
      Greetings !
      I have a .c4d project in <project_path>/my_project.c4d.
      I want to transfer some textures to <project_path>/tex folder but it doesn't always exist.
      Are there C4D calls to create the standard asset directory or do i have to do it manually with c++ calls ?
      thnx.
        On 31/08/2015 at 03:48, xxxxxxxx wrote:
        "Save as Project..." or "Save Project with Assets..." is the standard C4D procedure that does this.  You should use SaveProject() in C++.
          On 01/09/2015 at 05:33, xxxxxxxx wrote:
          you can also manually create the folder structure using the functions from GeFile. And BaseDocument provides GetDocumentPath().
            On 03/09/2015 at 12:53, xxxxxxxx wrote:
            Thank you very much for your responses !
