    Script for switching active cameras [SOLVED]
    5 Posts 0 Posters 504 Views
      On 18/08/2015 at 18:47, xxxxxxxx wrote:
      Is there any way to programmatically select a camera and set it to active view?
      I'm looking for the script property that relates to the little target button which allows you to look through a camera rather than the default editor camera. I'm sure there has to be a property that distinguishes whether it's on or not I but haven't been able to find any information about it, so I'm not sure if we have access to it or not.
        On 19/08/2015 at 06:18, xxxxxxxx wrote:
          On 19/08/2015 at 06:19, xxxxxxxx wrote:
          Look at the code I just posted in 'Command line parameter problem'. I think you answer is in there 🙂
            On 19/08/2015 at 09:33, xxxxxxxx wrote:
            welcome to the PluginCafe forums.
            Here's a small script switching to a selected camera (or editor camera, if none selected).
            from c4d import gui
                cam = doc.GetActiveObject()
                bd = doc.GetActiveBaseDraw()
                if (cam.GetType() != c4d.Ocamera) :
                    cam = None # switch to editor camera, if no camera selected
                bd.SetSceneCamera(cam)
              On 22/08/2015 at 21:44, xxxxxxxx wrote:
              Thank you Andreas!
              SetSceneCamera() is exactly what I was looking for, I knew it had to be there but for some reason I couldn't find it.
