    c4d.utils.splinehelp
    3 Posts 0 Posters 848 Views
      On 17/08/2015 at 08:18, xxxxxxxx wrote:
      Cinema 4D Version:   R16.050
      Platform:     Mac  ;  Mac OSX  ;
      Language(s) :
      Hello all,
      Within c4d.utils.splinehelp,     the following functions seem to be wrongly implemented:
          GetNormal: gives Tangent
          GetTangent: gives CrossNormal
          GetCrossNormal: gives Normal
      Not an urgent issue, because all functions are there, they just don't seem to have the right name.
      A piece of code in which this became evident is attached below. It should be executed from a python generator, with a spline as its child.
      kind regards,
      Hermen
      PS: if this code is going to be updated, a nice extra feature would be the GetMatrix function as described below, which evaluates the matrix at any given offset.
      #################  python code  ###################
      import math as m
      def GetMatrix(offset, segment, sh) :
          m1 = c4d.Matrix()
          GetNormal  gives Tangent
          GetTangent gives CrossNormal
          GetCrossNormal gives Normal
          m1.off = sh.GetPosition(offset, segment, realoffset=True)
          m1.v2  = sh.GetTangent(offset, segment, realoffset=True)
          m1.v3  = sh.GetNormal(offset, segment, realoffset=True) # not needed
          m1.v1 = sh.GetCrossNormal(offset, segment, realoffset=True)
          return m1
          spl = op.GetDown() # original spline
          sh  = c4d.utils.SplineHelp()
          sh.InitSpline(spl)
          N   = 2 * m.pi * 100  # op[c4d.ID_USERDATA,1] # N windings
          R   = 10 # op[c4d.ID_USERDATA,2] # Radius
          reverse = False #op[c4d.ID_USERDATA,3]
          phase   = 0. # op[c4d.ID_USERDATA,4]
          d   = 6 * N                 # density
          if reverse: N = -N
          newspl = c4d.SplineObject(d+1, 4)
          pts = range(d+1)
      for i in pts:
              #print i
              p = float(i)/d
              m0 = GetMatrix(p, 0, sh=sh)
              t = N * p + phase
              v = R * c4d.Vector(m.cos(t), m.sin(t), 0)
              pts _= m0*v
              if i==10000:
                  disc = c4d.BaseObject(c4d.Odisc)
                  disc[c4d.PRIM_AXIS] = 4 # z = tangent
                  disc.SetMg(m0)
                  disc.InsertUnder(newspl)
      newspl.SetAllPoints(pts)
          return newspl
        On 19/08/2015 at 00:07, xxxxxxxx wrote:
        thanks for reporting this, a bug report was filed. SplineHelp already has a GetMatrix() function.
          On 19/08/2015 at 14:21, xxxxxxxx wrote:
          Jee, how could I have missed that?!? I only noticed the "GetVertexMatrix" and never found this one.
          Thanks for pointing it out,
          Regards,
          Hermen
