    Indentation in Description Parameters [SOLVED]
    SDK Help
    0
    • H
      On 17/08/2015 at 01:14, xxxxxxxx wrote:
      Cinema 4D Version:   R16
      Greetings !
      I have created a really crowded description. There are a lot of parameters and at some point it appears confusing to which sub group each parameter belongs. I also use STATICTEXT to separate each of the groups.
      Is there some kind of indentation i could use for description parameters ?
      Thank you.
      • H
        On 17/08/2015 at 08:19, xxxxxxxx wrote:
        actually you can use almost any kind of grouping, that's used in other places of C4D.
        In descriptions groups and especially layout groups are probably the most common.
        • H
          On 26/08/2015 at 10:10, xxxxxxxx wrote:
          Wondering, if my answer was sufficient?
          • H
            On 26/08/2015 at 13:25, xxxxxxxx wrote:
            Yes it was.
            Thank you very much.
