    Render to PictureViewer without breaking plugin
    4 Posts 0 Posters 580 Views
      On 17/07/2015 at 09:00, xxxxxxxx wrote:
      Now that I've finally figured out how to create radio buttons in a res file (why was this info not available before in the forums?) and bitmap icons, there are just a few remaining roadblocks that I have become accustomed to.  If anyone is feeling magical and want to try to answer another longstanding question that I haven't been able to figure out, here you go (Thank you in advance!) :
      I have to break my plugins before Cinema will allow me to render to the picture viewer.  This hasn't been much of a problem because I need to break the plugins anyways to hand my projects over to my co-workers who are too inept to follow my repeated instructions on how to install my plugins (Anyone else have this problem?).  What code do I need to allow me to let Cinema render when I have an object plugin in the scene?  Let me know if I need to post any example code.
      P.S.:  Yeah, I know that these seem to simple questions, but as it turns out, the basics are the hardest things to find answers for in programming.
      -David
        On 20/07/2015 at 08:30, xxxxxxxx wrote:
        Hi David,
        can you please elaborate a bit more? What do you mean by "break my plugins"?`
        Also not sure about the "special code" to let Cinema render. I guess, you already know the Py-RoundedTube example from the Python SDK. This renders just fine.
          On 21/07/2015 at 10:42, xxxxxxxx wrote:
          Hi Andreas,
          By "break" I meant Make Editable.  Most of my object plugins don't render unless they are Made Editable, but some do.  I'll go ahead and post an entire plugin if it helps.  It doesn't have all of it's problems worked out, but the basic functionality works fine:
          import c4d, math, string, random
          from c4d import gui, plugins, utils, bitmaps
          import os
          # GoldenFlower 0.9
          # Author: David Cox
          # 07/01/2015
          PLUGIN_ID = 9329937
          #GROUP_FLOWER = 1000,
          PEDAL_LINK = 1001, # Pedal Link
          PEDAL_COUNT = 1002, # Number of pedals
          FLOWER_SPREAD = 1003, # Pedal Spread
          PEDAL_OPEN_AMOUNT = 1004, # Amount of open flower
          GROUP_BEND = 1005,
          BIAS_BEND = 1006, # Bend Bias
          BEND_AMOUNT = 1007, # Bend Amount
          RAND_BEND_AMOUNT = 1008, # Random Bend Amount
          BEND_HEIGHT = 1009, # Bend Height
          RAND_BEND_HEIGHT = 1010, # Random Bend Height
          RANDOM_SEED = 1011, # Random Bend Seed
          GROUP_TRANSFORMS = 1012,
          BIAS_POS = 1013, # Position Bias
          POS_X = 1014, # Pos-X
          RAND_POS_X = 1015, # Rand_Pos-X
          POS_Y = 1016, # Pos-Y
          RAND_POS_Y = 1017, # Rand_Pos-Y
          POS_Z = 1018, # Pos-Z
          RAND_POS_Z = 1019, # Rand_Pos-Z
          BIAS_SCALE = 1021, # Scale Bias
          SCALE_X = 1022, # Scale-X
          RAND_SCALE_X = 1023, # Rand_Scale-X
          SCALE_Y = 1024, # Scale-Y
          RAND_SCALE_Y = 1025, # Rand_Scale-Y
          SCALE_Z = 1026, # Scale-Z
          RAND_SCALE_Z = 1027, # Rand_Scale-Z
          BIAS_ROT = 1029, # Rotation Bias
          ROT_X = 1030, # Rot-X
          RAND_ROT_X = 1031, # Rand_Rot-X
          ROT_Y = 1032, # Rot-Y
          RAND_ROT_Y = 1033, # Rand_Rot-Y
          ROT_Z = 1034, # Rot-Z
          RAND_ROT_Z = 1035, # Rand_Rot-Z
          FLOWER_RADIUS = 1036, # Flower Radius
          MULTI_1 = 1037,
          MULTI_2 = 1038,
          MULTI_3 = 1039,
          MULTIBUTTON = 1040,
          RADIOBUTTONS = 1041,
          ABITMAPBUTTON_A = 1042,
          ABITMAPBUTTON_B = 1043,
          ABITMAPBUTTON_C = 1044,
          class GoldenFlower(c4d.plugins.ObjectData) :
              """GOLDEN FLOWER"""
              def __init__(self) :
                  self.SetOptimizeCache(True)
              def Init(self, op) :
                  self.InitAttr(op, float, [1002]) # Number of pedals
                  self.InitAttr(op, float, [1003]) # Pedal Spread
                  self.InitAttr(op, float, [1004]) # Amount of open flower
                  self.InitAttr(op, float, [1006]) # Bend Bias
                  self.InitAttr(op, float, [1007]) # Bend Amount
                  self.InitAttr(op, int, [1008]) # Random Bend Amount
                  self.InitAttr(op, float, [1009]) # Bend Height
                  self.InitAttr(op, int, [1010]) # Random Bend Height
                  self.InitAttr(op, int, [1011]) # Random Seed
                  self.InitAttr(op, float, [1013]) # Position Bias
                  self.InitAttr(op, float, [1014]) # Pos-X
                  self.InitAttr(op, int, [1015]) # Rand_Pos-X
                  self.InitAttr(op, float, [1016]) # Pos-Y
                  self.InitAttr(op, int, [1017]) # Rand_Pos-Y
                  self.InitAttr(op, float, [1018]) # Pos-Z
                  self.InitAttr(op, int, [1019]) # Rand_Pos-Z
                  self.InitAttr(op, float, [1021]) # Scale Bias
                  self.InitAttr(op, float, [1022]) # Scale-X
                  self.InitAttr(op, int, [1023]) # Rand_Scale-X
                  self.InitAttr(op, float, [1024]) # Scale-Y
                  self.InitAttr(op, int, [1025]) # Rand_Scale-Y
                  self.InitAttr(op, float, [1026]) # Scale-Z
                  self.InitAttr(op, int, [1027]) # Rand_Scale-Z
                  self.InitAttr(op, float, [1029]) # Rotation Bias
                  self.InitAttr(op, float, [1030]) # Rotation-X
                  self.InitAttr(op, int, [1031]) # Rand_Rotation-X
                  self.InitAttr(op, float, [1032]) # Rotation-Y
                  self.InitAttr(op, int, [1033]) # Rand_Rotation-Y
                  self.InitAttr(op, float, [1034]) # Rotation-Z
                  self.InitAttr(op, int, [1035]) # Rand_Rotation-Z
                  self.InitAttr(op, float, [1036]) # Flower Radius
                  op[1002] = 100.0  # Number of pedals
                  op[1003] = 0.8 # Pedal Spread
                  op[1004] = 10 # Amount of open flower
                  op[1006] = 0 # Bend Bias
                  op[1007] = 0 # Bend Amount
                  op[1008] = 0 # Random Bend Amount
                  op[1009] = 0 # Bend Height
                  op[1010] = 0 # Random Bend Height
                  op[1011] = 1 # Random Seed
                  op[1013] = 0 # Position Bias
                  op[1014] = 0 # Pos-X
                  op[1015] = 0 # Rand_Pos-X
                  op[1016] = 0 # Pos-Y
                  op[1017] = 0 # Rand_Pos-Y
                  op[1018] = 0 # Pos-Z
                  op[1019] = 0 # Rand_Pos-Z
                  op[1021] = 0 # Scale Bias
                  op[1022] = 0 # Scale-X
                  op[1023] = 0 # Rand_Scale-X
                  op[1024] = 0 # Scale-Y
                  op[1025] = 0 # Rand_Scale-Y
                  op[1026] = 0 # Scale-Z
                  op[1027] = 0 # Rand_Scale-Z
                  op[1029] = 0 # Rotation Bias
                  op[1030] = 0 # Rotation-X
                  op[1031] = 0 # Rand_Rotation-X
                  op[1032] = 0 # Rotation-Y
                  op[1033] = 0 # Rand_Rotation-Y
                  op[1034] = 0 # Rotation-Z
                  op[1035] = 0 # Rand_Rotation-Z
                  op[1036] = 3.0 # Flower Radius
              def Message(self, node, type, data) :
                  if type==c4d.MSG_DESCRIPTION_COMMAND:
                      if data['id'][0].id==1042:
                          self.thePedalA = True
                          self.thePedalB = False
                          self.thePedalC = False
                      if data['id'][0].id==1043:
                          self.thePedalB = True
                          self.thePedalA = False
                      if data['id'][0].id==1044:
                          self.thePedalC = True
                      node.Message(c4d.MSG_CHANGE)
              def GetVirtualObjects(self, op, hierarchyhelp) :
           # ******************** Set variables *************************************
                  v = c4d.Vector
                  rad = c4d.utils.Rad
                  doc = op.GetDocument()
                  baseNull = c4d.BaseObject(c4d.Onull)
                  pedal_MyData = op.GetDataInstance()
                  pedalLink = pedal_MyData.GetObjectLink(1001)
                  if pedalLink != None:
                      pedalLink[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = 1
                      pedalLink[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = 1
                  pedalNum = op[1002]
                  pedalSpread = op[1003]
                  openAmount = op[1004]/1000
                  bendBias = op[1006]
                  bendAmount = rad(op[1007])
                  randBendAmount = op[1008]
                  bendHeight = op[1009]*4
                  randBendHeight  = op[1010]
                  randSeed = random.seed(op[1011])
                  posBias = op[1013]
                  posX = op[1014]
                  randPosX = op[1015]
                  posY = op[1016]
                  randPosY = op[1017]
                  posZ = op[1018]
                  randPosZ = op[1019]
                  scaleBias = op[1021]
                  scaleX = op[1022]/100
                  randScaleX = op[1023]
                  scaleY = op[1024]/100
                  randScaleY = op[1025]
                  scaleZ = op[1026]/100
                  randScaleZ = op[1027]
                  rotBias = op[1029]
                  rotX = rad(op[1030])
                  randRotX = op[1031]
                  rotY = rad(op[1032])
                  randRotY = op[1033]
                  rotZ = rad(op[1034])
                  randRotZ = op[1035]
                  flowerRad = op[1036]
                  bitmapButtonA = op[1042]
                  bitmapButtonB = op[1043]
                  bitmapButtonC = op[1044]
                  # ******************** End Variable Assignment Area ******************
                  bound = flowerRad
                  rotVal = 0.0
                  tau = 6.28318530718 # pi * 2
                  phi = (1 + math.sqrt(5)) / 2 #1.618...
                  #calculate the golden angle in radians
                  golden_angle = tau * (2 - phi)
                  theta = 0.0
                  pedalTest_A = doc.SearchMaterial("Pedal_A")
                  pedalTest_B = doc.SearchMaterial("Pedal_B")
                  pedalTest_C = doc.SearchMaterial("Pedal_C")
                  path, fn = os.path.split(__file__)
                  fn = os.path.join(path, "pedals", "Pedal_A.c4d")
                  if pedalTest_A == None:
                      c4d.documents.MergeDocument(doc, fn, c4d.SCENEFILTER_OBJECTS | c4d.SCENEFILTER_MATERIALS, None)
                  if pedalTest_A != None:
                      c4d.documents.MergeDocument(doc, fn, c4d.SCENEFILTER_OBJECTS, None)
                      pedal_A = doc.GetActiveObjects(0)
                      tags = pedal_A[0].GetTags()
                      for p in tags:
                          if p.GetTypeName() == "Texture":
                              p.SetMaterial(pedalTest_A)
                  pedal_A = pedal_A[0]
                  pedal_A.InsertUnder(baseNull)
                  fn = os.path.join(path, "pedals", "Pedal_B.c4d")
                  if pedalTest_B == None:
                  if pedalTest_B != None:
                      pedal_B = doc.GetActiveObjects(0)
                      tags = pedal_B[0].GetTags()
                      for p in tags:
                              p.SetMaterial(pedalTest_B)
                  pedal_B = pedal_B[0]
                  pedal_B.InsertUnder(baseNull)
                  fn = os.path.join(path, "pedals", "Pedal_C.c4d")
                  if pedalTest_C == None:
                  if pedalTest_C != None:
                      pedal_C = doc.GetActiveObjects(0)
                      tags = pedal_C[0].GetTags()
                      for p in tags:
                              p.SetMaterial(pedalTest_C)
                  pedal_C = pedal_C[0]
                  pedal_C.InsertUnder(baseNull)
                  doc.SetSelection(op)
                  pedal_A[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = 1
                  pedal_A[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = 1
                  pedal_B[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = 1
                  pedal_B[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = 1
                  pedal_C[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = 1
                  pedal_C[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = 1
                  if self.thePedalA == True:
                      thePedal = pedal_A
                  if self.thePedalB == True:
                      thePedal = pedal_B
                  if self.thePedalC == True:
                      thePedal = pedal_C
                  for n in range(int(pedalNum)) :
                      if pedalLink == None:
                          pedalClone = thePedal.GetClone()
                          pedalClone = c4d.utils.SendModelingCommand(command=c4d.MCOMMAND_CURRENTSTATETOOBJECT, list=[pedalClone], bc=c4d.BaseContainer(), mode=c4d.MODELINGCOMMANDMODE_ALL, doc = doc, flags = 0)
                          pedalClone = pedalClone[0]
                          pedalBound = pedalClone.GetRad() # Get the bounding box
                          pedalBound += pedalBound
                          radius = (bound * pow(n/pedalNum, pedalSpread)) * 10
                          theta += golden_angle
                          pos = self.polar_to_cartesian(theta, radius) #Call def
                          self.makeThing(n, pos, radius, rotVal, baseNull, pedalNum, pedalClone, pedalBound, bendAmount, bendHeight, randBendAmount, randBendHeight, bendBias, posBias, scaleBias, rotBias, randPosX, randPosY, randPosZ, randScaleX, randScaleY, randScaleZ, randRotX, randRotY, randRotZ, posX, posY, posZ, scaleX, scaleY, scaleZ, rotX, rotY, rotZ)
                          rotVal += openAmount
                          if n > 0:
                              pedalClone[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = 2
                              pedalClone[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = 2
                          pedalType = pedalLink.GetTypeName()
                      if pedalLink != None and pedalType != "Legacy XRef":
                          pedalClone = pedalLink.GetClone()
                          if n > 0:
                  return baseNull
              def makeThing(self, n, pos, radius, rotVal, baseNull, pedalNum, pedalClone, pedalBound, bendAmount, bendHeight, randBendAmount, randBendHeight, bendBias, posBias, scaleBias, rotBias, randPosX, randPosY, randPosZ, randScaleX, randScaleY, randScaleZ, randRotX, randRotY, randRotZ, posX, posY, posZ, scaleX, scaleY, scaleZ, rotX, rotY, rotZ) :
                  rad = c4d.utils.Rad
                  theThing = pedalClone
                  theThing.SetRelPos(pos)
                  theScale = pow(radius,0.5)*0.265
                  pos = -pos
                  N = pos.GetNormalized()
                  upVec = c4d.Vector(0,1,0)
                  dist = pos.GetLength()
                  nn = c4d.utils.VectorToHPB(N)
                  norm = c4d.Vector(0,0,0)
                  if N != None:
                      norm = nn.Cross(upVec).GetNormalized()
                  #norm = c4d.Vector(nn.x + rotVal, N.y + rotVal*0.3, nn.z)
                  norm = c4d.Vector(nn.x, N.y + rotVal*0.3, nn.z)
                  theThing.SetRelRot(norm)
                  rot = theThing.GetRelRot()
                  scale = theThing.GetRelScale()
                  pos = theThing.GetRelPos()
                  rand = float(random.randrange(-100, 100))/100
                  randBendAmount *= rand
                  randBendAmount = randBendAmount/100
                  randBendHeight *= rand
                  randPosX *= rand
                  randPosY *= rand
                  randPosZ *= rand
                  randScaleX *= rand
                  randScaleX = randScaleX/100
                  randScaleY *= rand
                  randScaleY = randScaleY/100
                  randScaleZ *= rand
                  randScaleZ = randScaleZ/100
                  randRotX *= rand
                  randRotX = randRotX/100
                  randRotY *= rand
                  randRotY = randRotY/100
                  randRotZ *= rand
                  randRotZ = randRotZ/100
                  theThing.SetRelPos(c4d.Vector(posX+pos.x+randPosX, posY+pos.y+randPosY, posZ+pos.z+randPosZ))
                  theThing.SetRelScale(c4d.Vector(scaleX+scale.x+randScaleX, scaleY+scale.y+randScaleY, scaleZ+scale.z+randScaleZ))
                  theThing.SetRelRot(c4d.Vector(rotX+rot.x+randRotX, rotY+rot.y+randRotY, rotZ+rot.z+randRotZ))
                  pedalBend = c4d.BaseObject(c4d.Obend)
                  pedalBend.InsertUnder(theThing)
                  pedalBend[c4d.DEFORMOBJECT_SIZE] = pedalBound
                  pedalBend[c4d.DEFORMOBJECT_STRENGTH] = bendAmount+randBendAmount
                  pedalBend[c4d.BENDOBJECT_KEEPYAXIS] = True
                  pedalBend[c4d.DEFORMOBJECT_ANGLE] = rad(-90)
                  pedalBend[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = 1
                  #print "n: ",n
                  #print "pedalNum: ", pedalNum
                  pedalBend[c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Y] = pedalBound.y/2 + bendHeight+randBendHeight
                  #pedalBend[c4d.DEFORMOBJECT_STRENGTH] = (bendAmount+randBendAmount) + 10*(pow(bendBias, n/pedalNum))
                  theThing.InsertUnder(baseNull)
              def polar_to_cartesian(self, theta, radius) :
                  sn, cs = c4d.utils.SinCos(theta)
                  return c4d.Vector(cs*radius, 0, sn*radius)
              def SetGlobalPosition(self, obj, pos) :
                  m = obj.GetMg()
                  m.off = pos
                  obj.SetMg(m)
              def SetGlobalRotation(self, obj, rot) :
                  m = obj.GetMg()
                  pos = m.off
                  scale = c4d.Vector( m.v1.GetLength(),
                                      m.v2.GetLength(),
                                      m.v3.GetLength())
                  m = utils.HPBToMatrix(rot)
                  m.off = pos
                  m.v1 = m.v1.GetNormalized() * scale.x
                  m.v2 = m.v2.GetNormalized() * scale.y
                  m.v3 = m.v3.GetNormalized() * scale.z
                  obj.SetMg(m)
          BITMAP_ID1 = 103721
          BITMAP_ID2 = 103722
          BITMAP_ID3 = 103723
              #main()
              fn = os.path.join(dir, "res", "Icon.tif")
              bmp.InitWith(fn)
              buttonimageA = bitmaps.BaseBitmap()                         #We need an instance of BaseBitmap class to use an image
              buttonimageA.InitWith(os.path.join(path, "res", "pedal_A.tif"))#The location where the button image exists
              buttonimageB = bitmaps.BaseBitmap()                         #We need an instance of BaseBitmap class to use an image
              buttonimageB.InitWith(os.path.join(path, "res", "pedal_B.tif"))#The location where the button image exists
              buttonimageC = bitmaps.BaseBitmap()                         #We need an instance of BaseBitmap class to use an image
              buttonimageC.InitWith(os.path.join(path, "res", "pedal_C.tif"))#The location where the button image exists
              gui.RegisterIcon(BITMAP_ID1, buttonimageA)                  #We need to register custom images & icons
              gui.RegisterIcon(BITMAP_ID2, buttonimageB)                  #We need to register custom images & icons
              gui.RegisterIcon(BITMAP_ID3, buttonimageC)                  #We need to register custom images & icons
              result = plugins.RegisterObjectPlugin(
                  id=PLUGIN_ID,
                  str="GoldenFlower",
                  g=GoldenFlower,
                  description="Ogolden_flower",
                  info=c4d.OBJECT_GENERATOR,
                  icon=bmp
            On 22/07/2015 at 03:49, xxxxxxxx wrote:
            I'm sorry, we are not supposed to debug code. And it would be a good idea to give at least an overview, what your code is supposed to do.
            I briefly looked over your code and I think you have several problems in there.
            Most important:
            You are not allowed to modify the active scene with GetVirtualObjects(). Please have look at documentation on ObjectData, GetVirtualObjects() and important threading information.
            I noticed for example MergeDocument().
            Objects can only be inserted once into a scene, while you try to get the active object and insert it under your generated object. That won't work for several reasons:
            - The active object is already in the scene and you can't remove it, because you are not allowed to in GVO. Instead you should have a look at the OBJECT_INPUT flag on RegisterObjectPlugin().
            - Getting the active object makes no sense during rendering. The scene gets copied for rendering and there simply won't be any active object in there.
            You are loading several scene files with MergeDocument(), which (as mentioned before) already is a bad idea, but think of situations like for example TeamRender. How is TeamRender supposed to find these files on a different machine?
            I think, you will have to rework and restructure your plugin to properly work in all situations, especially for rendering. Sorry, to say this.
