    Check if object is a polygonal parametric object
    9 Posts 0 Posters 700 Views
      On 16/07/2015 at 15:27, xxxxxxxx wrote:
      I know that obj.GetInfo() & c4d.OBJECT_ISSPLINE will return True if the obj is a spline, no matter if it is a "manual" spline or a parametric spline.
      But how can I check if a object is a parametric "polygonal" object?
      I mean, how can I check if an object, even if it is a generator, generates a polygonal object?
        On 16/07/2015 at 17:49, xxxxxxxx wrote:
        Hi
        flash idea - op.GetPointCount() ?!
        or i'm finding solutions that someone make dict with oplist of id's and check out ops from dict
          On 16/07/2015 at 18:03, xxxxxxxx wrote:
          I want to consider parametric objects as candidates that fulfill the check.
          So, a Cube or a Sphere would be considered as "polygonal" objects by my code, even if they start as parametric.
          But a Light or a Null would not, because they produce no geometry.
          So, the op.GetPointCount() would not work as it only works with really polygonal objects.
          I guess I will have to create a list with all the IDs and check with something like:
          if op.GetType() in ID_list:
          Not as elegant and much more complex.
            On 16/07/2015 at 18:28, xxxxxxxx wrote:
            Hello Rui,
            you might need some additional if clauses for PythonGenerators, but basically you can use something like this snippet(in R16- otherwise  if op.GetType() == c4d.Opolygon:
              if not op: return
              if op.IsInstanceOf(c4d.Opolygon) :
                  print "polygonalobject"
                  base = op.GetCache()
                  if base:
                      if base.IsInstanceOf(c4d.Opolygon) :
            Hope this helps?
            Best Wishes
            Martin
              On 17/07/2015 at 01:31, xxxxxxxx wrote:
              there are no "polygonal parametric" objects. In Cinema there are generators that fill a cache – possibly with polygon objects. So you would have to check if a given object is a generator and then search the cache for polygon objects.
              See also
              • "Polygon-Object or Scene Object"
              • "Detecting if a BaseObject is a Generator"
                On 17/07/2015 at 01:45, xxxxxxxx wrote:
                I know there are no "polygonal parametric" objects. It was just a way to differentiate parametric objects that generate geometry from the ones that don't
                I will check out that cache thing.
                Thank you all.
                  On 22/10/2015 at 03:59, xxxxxxxx wrote:
                  Hello
                  Sorry for necromancy of topic 😉
                  I found additional similar method, ... well known method:
                  if hasattr(op, 'GetAllPoints') == False: return # or any stuff with procedural
                  else -   possible to csto procedural and return point op
                    On 22/10/2015 at 06:57, xxxxxxxx wrote:
                    @Ilya: That would be the same as using op.CheckType(c4d.Opoint). The OP wanted to know whether the
                    object generates  a polygonal object, not if it is  a polygonal object. And actually you'd have to test for
                    c4d.Opolygon  and 'GetAllPolygons' , otherwise you'd only check for point objects.
                    -N
                      -N
                      Hi
                      Argh, thank you
                      i made universal link-gui to op(without ACCEPT flag), i got this method when i looked at console and it wrote about no attribute. Then i remember my battles with pySide, SWIG... expesially attributes for objects and etc.
