    Python Scripting Tag Global Variables
    3 Posts 0 Posters 298 Views
      On 15/07/2015 at 21:31, xxxxxxxx wrote:
      Hello Forum,
      After reading these great posts:
      https://developers.maxon.net/forum/topic/8461/11042_python-tag-catch-button-presson-parent-object&KW=user+data+button&PID=43468#43468 Thanks Niklas.
      https://developers.maxon.net/forum/topic/8312/10843_user-button-test-on-python-generator-solved&KW=user+data+button&PID=42531#42531 Thanks Sebastian.
      I realized there is much to learn about Python Scripting Tags.
      Where are the global variables for the Python Scripting Tags documented?
      By reading other posts/examples, I understand that "op" and "doc" are global variables, but I did knot know there was a global function like message(msg_type, data) : available in a scripting tag.
      I do not understand how message(msg_type, data) works in the scripting tag.  How is it getting called?  Is it like a virtual method in c++?  Are there other functions like this available?
      Thank you,
      Joe Buck
        On 16/07/2015 at 02:03, xxxxxxxx wrote:
        Hi Joe,
        The Python documentation is currently lacking information on Python scripting features (tags, scripts, XPresso node etc).
        main() in a Python tag is the same as TagData::Execute() and the available global variables are:
        doc : the host document of the tag.
        flags : the execution flags.
        priority : the execution priority in the pipeline (EXECUTIONPRIORITY_INITIAL, EXECUTIONPRIORITY_ANIMATION, EXECUTIONPRIORITY_GENERATOR etc).
        op : the Python tag.
        bt : the calling thread.
        tp : the TP master system for the host document if there's one.
        message(id, data) in a Python tag behaves the same as TagData::Message().
        It receives the data as Python dictionaries with the entries matching the names used in the C++ API for the structure members.
        The available global variables are the same as in main() except that flags and priority does not make sense in message().
          On 16/07/2015 at 08:20, xxxxxxxx wrote:
          Thank you Yannick.  This is solved.
