    RayObject and polygon selections/textures [SOLVED]
    3 Posts 0 Posters 383 Views
      On 06/07/2015 at 23:01, xxxxxxxx wrote:
      Cinema 4D Version:   15+
      consider a polygon object which got many different textures, each with its own selection, how to retrieve this data through RayObject "I searched and found old threads, found this thread: https://developers.maxon.net/forum/topic/3147/2527_uvw-projections&KW=rsadr "
      it has an example, but it is not a complete one, may be more clarification here please.
        On 07/07/2015 at 07:38, xxxxxxxx wrote:
        the index of the restriction is stored in the TexData object (TexData::restrict). With that index you can check if there is a restriction and then you can test if a given polygon is selected or not. Something like this:
        // get selection
        const Int32 selection = texData->restrict;
        // if there is a selection
        if(selection != 0)
         // check for each polygon
         for (Int32 polyIndex = 0; polyIndex < rayObject->vcnt; ++polyIndex)
             GePrint("Texture "+String::IntToString(textureIndex) + ", Polygon "+String::IntToString(polyIndex));
             if ((rayObject->rsadr[texData->restrict][polyIndex >> 5] & (1 << (polyIndex & 31))) == 0)
                 GePrint("not selected");
             else
                 GePrint("selected");
          On 07/07/2015 at 07:42, xxxxxxxx wrote:
          thanks a lot Sebastian , consider this solved.
