    Please explain this code
    7 Posts 0 Posters 583 Views
      On 01/07/2015 at 01:00, xxxxxxxx wrote:
      Hey guys
      I came across some python code for cinema 4d here:http://code.vonc.fr/?a=21
      This is i am trying to reverse engineer it how he made the code.
      Can somebody pls explain the algorithm or the process he used for making this plugin (allowing alternate selections). I know I am asking for a lot ( website is in french!!!) but it would be gr8 if someone gave a detailed explanation and not just hints.
      Thanks a lot in advance.
      any help would be appreciated (you can link me to resources where i can learn about handling polygon selections in python for cinema 4d).
        On 01/07/2015 at 02:21, xxxxxxxx wrote:
        My approach would be to:
        Translate and replace all the french words.
        Add a print statement to every function.
        Look up all the SDK methods in there to get a feel for what they do and what class they belong to.
        Run it in cinema to get a feel for what it does.
        Or just email the guy and ask 🙂
        -b
          On 01/07/2015 at 03:40, xxxxxxxx wrote:
          I have tried playing with the plugin but i cannot understand what Sélectionner, Sur and Décalage do.
          They have varied translation in french. The author is not replying mails. I guess its an old account he uses no more.
          for eg. Decalage means shift in english. It means the intervals right? but it is not working so.
            On 01/07/2015 at 04:40, xxxxxxxx wrote:
            I'll leave the code discussion to the community.
            From my side only a link, where BaseSelect class is documented.
              On 01/07/2015 at 05:49, xxxxxxxx wrote:
              @CreamyGiraffe Try PM him here: César[URL-REMOVED]
                On 01/07/2015 at 14:20, xxxxxxxx wrote:
                An upgrated version of this script including a lot of selections tools is available here in French, English and Czech, CreamyGiraffe : http://code.vonc.fr/?a=23
                I can't explain you all the algo, but you might find all you need with the Neighbor class :
                https://developers.maxon.net/docs/py/2023_2//help/modules/c4d.utils/Neighbor/index.html?highlight=neighbor
                You start at a selected poly and search the selected neighbor polys from it, and the selected neighbor of the neighbors, etc.
                PS : It's not because I don't answer you in the day that my address is unused...
                  On 02/07/2015 at 03:16, xxxxxxxx wrote:
                  thanks César
