    SelectionChanger example [SOLVED]
    10 Posts 0 Posters 1.0k Views
      On 30/06/2015 at 12:09, xxxxxxxx wrote:
      Cinema 4D Version:   R16
      Platform:      Mac OSX  ;
      I need to convert a selection of edges in a multi-selection of objects to points.
      I know I have to create modelingcommanddata for this.
      Here is what I've got so far:
      ModelingCommandData cd;
      cd.doc = doc;
      cd.arr = selection;
      But how do I assign the left, right and tolerance??
      https://developers.maxon.net/docs/cpp/2023_2/group\_\__m\_d_a\_t_a\_\__c\_o_n\_v_e\_r_t\_s_e\_l_e\_c_t\_i_o\_n.html
      Left should be edges, right points and tolerance false.
      Greetings,
      Casimir Smets
        On 30/06/2015 at 14:10, xxxxxxxx wrote:
        I would think that you set the three parameters for the MCOMMAND_CONVERTSELECTION call in a BaseContainer that is attached to the ModelingCommandData bc field.
        BaseContainer bc;
        bc.SetInt32(MDATA_CONVERTSELECTION_LEFT, 1);  // From Edges
        bc.SetInt32(MDATA_CONVERTSELECTION_RIGHT, 0); // To Points
        bc.SetBool(MDATA_CONVERTSELECTION_TOLERANT, false);
        cd.doc = doc;
        cd.arr = selection;
        cd.bc = &bc;
        // Etc.
          On 01/07/2015 at 01:50, xxxxxxxx wrote:
          Hi Robert!
          Yeah, I thought it to be something like that.
          I've tested the following code, but it doesn't work:
          BaseContainer bc;
          cd.doc = doc;
          cd.arr = selection;
          cd.bc = &bc;
          if (!SendModelingCommand(MCOMMAND_CONVERTSELECTION, cd))
            return false;
          EventAdd();
          I do this inside a CommandData/GeDialog plugin, inside Command of the dialog, when a button is pressed.
          Does somebody have any idea what could be wrong?
          Greetings,
          Casimir Smets
            On 01/07/2015 at 04:44, xxxxxxxx wrote:
            Hi Casimir,
            you could also check the SelectionChanger class. Maybe it helps.
              On 01/07/2015 at 05:02, xxxxxxxx wrote:
              Hi Andreas,
              Thanks for your answer!
              That looks like something I could use!
              I will definately look into this 😄
              Greetings,
              Casimir Smets
                On 01/07/2015 at 08:25, xxxxxxxx wrote:
                I have one problem: I can't get the selected points.
                If I try:
                if (!selectionChanger->GetPoints())
                  GePrint("The selection changer couldn't get the selected points!");
                the console prints out my GePrint...
                Here is my relevant code:
                AutoAlloc<AtomArray> selection;
                if (!selection) return false;
                Vector globalModelingAxis = doc->GetHelperAxis()->GetMg().off;
                Vector projection = newPosition;
                if (setX == true)
                  projection.x = newPosition.x - globalModelingAxis.x;
                if (setY == true)
                  projection.y = newPosition.y - globalModelingAxis.y;
                if (setZ == true)
                  projection.z = newPosition.z - globalModelingAxis.z;
                AutoAlloc<SelectionChanger> selectionChanger;
                for (Int32 x = 0; x < selection->GetCount(); x++)
                   GePrint("Inside the object iteration!");
                   PolygonObject *opPoly = static_cast<PolygonObject*>(selection->GetIndex(x));
                   if (!opPoly) return false;
                   GePrint("Inside the object iteration - first return!");
                   BaseSelect *edgeSelection = opPoly->GetEdgeS();
                   if (!edgeSelection) return false;
                   GePrint("Inside the object iteration - second return!");
                   if (!selectionChanger->InitFromSelection(edgeSelection, Medges))
                        GePrint("The selection changer didn't initialize!");
                        return false;
                   else
                       GePrint("The selection changer did initialize!");
                   if (!selectionChanger->GetPointS())
                   BaseSelect *pointSelection = selectionChanger->GetPointS();
                   if (!pointSelection) return false;
                   GePrint("Inside the object iteration - third return!");
                   Vector *points = opPoly->GetPointW();
                   if (!points) return false;
                   GePrint("Inside the object iteration - END!");
                   for (Int32 y = 0; y < opPoly->GetPointCount(); y++)
                       if (pointSelection->IsSelected(y))
                           GePrint("The point from edge is selected!");
                           points[y] = points[y] + projection;
                  opPoly->Message(MSG_UPDATE);
                I hope somebody can help!
                With kind regards,
                Casimir Smets
                  On 03/07/2015 at 05:04, xxxxxxxx wrote:
                  you forgot to pass the object when initializing the SelectionChanger.
                  This:
                  has to be:
                  if (!selectionChanger->InitFromSelection(edgeSelection, Medges, opPoly))
                    On 03/07/2015 at 06:06, xxxxxxxx wrote:
                    Hi Andreas,
                    Thanks for your answer! That did the trick!
                    You can mark this thread as solved!
                    Greetings,
                    Casimir Smets
                      On 03/07/2015 at 06:25, xxxxxxxx wrote:
                      One last thing, could you please change the name to something like this: SelectionChanger example.
                      Thank you very much!
                      Greetings,
                      Casimir Smets
                        On 03/07/2015 at 06:26, xxxxxxxx wrote:
                        Good thought 🙂
