    Accessing HUD elements
    3 Posts 0 Posters 401 Views
      On 29/06/2015 at 07:20, xxxxxxxx wrote:
      Cinema 4D Version:   16
      Platform:      Mac OSX  ;
      Language(s) :     C++  ;   PYTHON  ;
      Hi everyone,
      I was wondering if there is anything in the SDK for Python or C++ to access HUD elements. All I'm looking to do at this stage is have control of the positions of HUD objects like a user data slider or an info string.
      Adam
        On 30/06/2015 at 07:48, xxxxxxxx wrote:
        Hi Adam,
        It's currenly only possible to access the HUD elements (or controls) with the C++ API. Note the library lib_viewport.h that enables this access isn't documented and doesn't appear in the documentation. See this header to know its definitions.
        Here's a simple code snippet to access an existing HUD added to an integer user data with ID 1:
        AutoAlloc<ViewportHUD> viewHUD;
        if (!viewHUD)
          return false;
        ViewportHUDControl* control = viewHUD->FindControl(doc, doc->GetActiveBaseDraw(), op, DescID(DESCID_DYNAMICSUB, DescLevel(1, DTYPE_LONG, 0)));
        if (!control)
          return false;
        doc is the active document and op the active object.
        Then to control the position ViewportHUDControl has the method SetTopLeft().
          On 30/06/2015 at 08:44, xxxxxxxx wrote:
          Amazing thanks, that looks like what I need.
