    Object Links during render?
    3 Posts 0 Posters 649 Views
      On 28/01/2003 at 02:01, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      I've been trying to track down a problem where I get completely different results when rendering to the editor than I do when rendering to picture viewer.
      I'm using a custom shader which is dependent upon an external object (like the SLA proximal shader).
      My plugin includes the following in the 'Output()' method to access the object:
      BaseDocument *bd   = GetActiveDocument();
      BaseContainer *data = chn->GetDataInstance();
      obj = data->GetObjectLink(MY_REF, bd);
      This correctly returns the object when it is rendering the view in the editor window, but returns a NULL link when rendering to the picture viewer...
      Am I doing something wrong, or is this a bug.
      How does proximal access the object data?
      Thanks for any help.
      Cheers - Steve
        On 28/01/2003 at 02:42, xxxxxxxx wrote:
        When you render to the picture viewer the document is cloned (since it is running in a thread), the active document should never be used for anything other than a tool, a shader can find out which document it is rendering. As for the links, I'm not sure what happens to them when you clone a document, maybe someone else can tell you.
          On 28/01/2003 at 04:51, xxxxxxxx wrote:
          Hi David,
          Thanks for the info, I think I see the problem now. Instead of
          I should have
          BaseDocument *bd = irs->doc;
          I guess that the link is failing because it's taken from the 'irs->doc' document, and I was trying to find it in the 'active' document.
          I'll try this tonight, but it sounds promising.
          Thank you!
          Cheers - Steve
