    weird behavior in MaterialData Init() [SOLVED]
    19 Posts 0 Posters 1.9k Views
      On 29/06/2015 at 22:23, xxxxxxxx wrote:
      well. doing it in constructor didn't work "simply because it is calling Alloc() ..."
      so what I want to achieve:
      store some data inside the material "is this possible with local variables? or I have to use descriptions"
        On 01/07/2015 at 06:02, xxxxxxxx wrote:
        Hi Mohamed,
        you already found out, that the constructor is a bad idea.
        But why not use Init()? If you have a problem with multiple initializations, you could simply have a flag in your class, which gets set after the initialization is done. Next time you enter Init() you simply check the flag and exit.
          On 01/07/2015 at 07:58, xxxxxxxx wrote:
          this is horrible!!!, the class is constructed multiple times, how will the flag work?
          I wanted to create a singleton flag for any purpose inside the class, but as the class is created everytime it calls matpreview, it doesn't work "all class members are thrown away and I can't rely on Init()"
          for example:
          Init() { m_update_preview = TRUE;}
          and in the mat preview render:
          if(m_update_preview) { m_update_preview = FALSE; render();}
          this is totally won't work, no class members are working as it is initialized multiple times, what should I do?
            On 01/07/2015 at 08:00, xxxxxxxx wrote:
            So you have global data, that is used by all instances your material class?
            In such cases I tend to use a globally static variable as a flag.
              On 01/07/2015 at 08:37, xxxxxxxx wrote:
              not global.
                On 02/07/2015 at 05:30, xxxxxxxx wrote:
                You don't want a global flag? Then, why not?
                You have no global data? Fine.
                But your problem are those repeated Init() calls, right?
                Regarding my suggestion of a flag as member variable. This could still work, if you correctly implement it in Read()/Write() and CopyTo().
                  On 02/07/2015 at 09:23, xxxxxxxx wrote:
                  I see, so descriptions can solve this? "trying to avoid overriding Read()/Write()"
                    On 02/07/2015 at 17:45, xxxxxxxx wrote:
                    to some extent, the problem is half solved, here is what I did:
                    used CopyTo() , which solved how the buttons work "in the video, I have 2 buttons, one that sets the flag to TRUE and one sets it to FALSE"
                    now the problem is: I want to set the flag to FALSE after the render, some code:
                    		case MATPREVIEW_GENERATE_IMAGE:
                    				MatPreviewGenerateImage* image = (MatPreviewGenerateImage* )data;
                    				if (image->pDoc)
                    					Int32					w = image->pDest->GetBw();
                    					Int32					h = image->pDest->GetBh();
                    					RenderData* rdata = image->pDoc->GetActiveRenderData();
                    					BaseContainer bcRender = rdata->GetData();
                    					bcRender.SetFloat(RDATA_XRES, w);
                    					bcRender.SetFloat(RDATA_YRES, h);
                    					bcRender.SetInt32(RDATA_ANTIALIASING, ANTI_GEOMETRY);
                    					image->pDest->Clear(0, 0, 0);
                    					GePrint("m_update_preview = " + String::IntToString(m_update_preview));
                    					if(image->bLowQuality)
                    						bcRender.SetBool(RDATA_RENDERENGINE, RDATA_RENDERENGINE_PREVIEWSOFTWARE);
                    						image->lResult = RenderDocument(image->pDoc, bcRender, nullptr, nullptr, image->pDest,
                    															 RENDERFLAGS_EXTERNAL | RENDERFLAGS_PREVIEWRENDER, image->pThread);
                    					else if(m_update_preview == TRUE)
                    						((SevenPhotonsMaterial* )node)->m_update_preview = FALSE;
                    						BaseVideoPost* myRenderer = BaseVideoPost::Alloc(ID_SEVENPHOTONS);
                    						rdata->InsertVideoPost(myRenderer);
                    						bcRender.SetInt32(RDATA_RENDERENGINE, ID_SEVENPHOTONS);
                    															 RENDERFLAGS_EXTERNAL, image->pThread);
                    				break;
                    		case MSG_DESCRIPTION_COMMAND:
                    				DescriptionCommand* dc = (DescriptionCommand* )data;
                    				if (dc->id[0].id == SEVENPHOTONS_MAT_PREVIEW_UPDATE)
                    					break;
                    				else if (dc->id[0].id == SEVENPHOTONS_MAT_PREVIEW_UPDATE_STOP)
                    					break;
                    so with the 2 commands, it works fine, but it doesn't change to FALSE in the MATPREVIEW_GENERATE_IMAGE message, any ideas?
                      On 03/07/2015 at 05:45, xxxxxxxx wrote:
                      Hm? My questions may be stupid...
                      Are those cases in the same switch? Then why do you access m_update_preview directly in MSG_DESCRIPTION_COMMAND and via a node in MATPREVIEW_GENERATE_IMAGE?
                      Otherwise without knowing your class layout it's difficult to tell. Maybe you are resetting the flag in a copy?
                        On 03/07/2015 at 07:47, xxxxxxxx wrote:
                        not via a node
                        this: ((SevenPhotonsMaterial* )node)->m_update_preview = FALSE;
                        is the same as this: m_update_preview = FALSE;
                        it is a class member.
                        what I wanted to achieve is: when I hit update button,it renders "only once" //this one didn't work,
                        as it is perma updating, that's why I tried setting the flag to false once it enters "old singleton style"
                        when I hit cancel button,it breaks any rendering. //I achieved this
                          On 06/07/2015 at 09:01, xxxxxxxx wrote:
                          Hi Mohamed,
                          the reason you can't reset the flag is indeed, that you are working on a copy. MATPREVIEW_GENERATE_IMAGE is send to a clone of your material for rendering purposes.
                          That being said, I have to say, I have no solution, yet. I'm currently looking into MATPREVIEW_GET_DIRTY_COUNT and MATPREVIEW_COPY_USERDATA, if these might offer a solution. I will also discuss your case with the rest of the team tomorrow.
                          I'm sorry, this thread is taking so long and I still can't offer a solution. But I'm still optimistic, we'll find a solution.
                            On 23/07/2015 at 08:21, xxxxxxxx wrote:
                            Hi Mohamed,
                            finally I found the time to play around with this. Sorry, it took so long.
                            As said before, the problem is, that MATPREVIEW_GENERATE_IMAGE is send to a clone of your material. So you can't reset the flag, because you only reset it in the clone, not the original material.
                            My admittedly quite hacky approach is to have a BaseLink member (_linkOrig) in the material. Plus another boolean member (_flagRequestPreview) storing the "render request" flag.
                            In Init() I initialize as follows:
                            _linkOrig->SetLink(nullptr);
                            _flagRequestPreview = true; // assuming that a first initial preview is always wanted
                            When the material is copied (CopyTo()), I set the link. Either to the source material (if not previously set) or to the stored link. Like so:
                            MaterialPreviewExample* sdata = static_cast<MaterialPreviewExample*>(snode->GetNodeData());
                            BaseList2D* bl2d = sdata->_linkOrig->GetLink(snode->GetDocument());
                            if (bl2d)
                              static_cast<MaterialPreviewExample*>(dest)->_linkOriginalMaterial->SetLink(bl2d);
                            else
                              static_cast<MaterialPreviewExample*>(dest)->_linkOriginalMaterial->SetLink(snode);
                            In MSG_DESCRIPTION_COMMAND I do basically the same as you, simply setting _flagRequestPreview. Of course one could use a checkbox instead of two buttons, but that may be a matter of taste.
                            Then on MATPREVIEW_GENERATE_IMAGE I simply evaluate the link and use/reset the flag of the original material. Like so:
                            BaseList2D* bl2d = _linkOrig->GetLink(node->GetDocument());
                            if (!bl2d)
                              bl2d = _linkOrig->ForceGetLink();  // this will be the most probable path, as preview is rendered in another document
                            Bool flagRender;
                            if (bl2d)
                              MaterialPreviewExample* dOrig = static_cast<MaterialPreviewExample*>(bl2d->GetNodeData());
                              flagRender = dOrig->_flagRequestPreview;
                              dOrig->_flagRequestPreview = false;
                            else
                              flagRender = _flagRequestPreview;
                            // Here: flagRender is true, only once after the button got pushed
                            As I said, it's a bit hacky. But as it is only used for rendering of previews, I think, it should work ok.
                            Let me know, what you think.
                            Another option would be the use of message MATPREVIEW_PREPARE_SCENE. As far as I can see, this message is still send to the original material. But if you get this message, heavily depends on your preview implementation.
                              On 23/07/2015 at 09:01, xxxxxxxx wrote:
                              Hi Andreas,
                              thanks a lot for the help
                              I will check them tonight and see , most probably the link approach looks good "I will need that link for other stuff later 😄
                                On 23/07/2015 at 22:18, xxxxxxxx wrote:
                                it works very well, thanks Andreas
                                you can consider this solved.
