    Get/SetDParameter + CUSTOMDATATYPE_SPLINE [SOLVED]
    13 Posts 0 Posters 1.5k Views
      On 03/07/2015 at 06:08, xxxxxxxx wrote:
      Can you post some code? If you want to keep it secret, you could also send it to sdk_support or via PM.
      I'd also be interested in the Get/SetDParameter() implementation, that broke the keyframes.
        On 03/07/2015 at 07:42, xxxxxxxx wrote:
        sure, here is some code:
        in MaterialData:
        Bool SevenPhotonsMaterial::GetDParameter(GeListNode* node, const DescID& id, GeData& t_data, DESCFLAGS_GET& flags)
        	BaseContainer* data = ((BaseMaterial* )node)->GetDataInstance();
        	GeData knd(SEVENPHOTONS_NODE_CUSTOMDATATYPE, iSnodeDataType(m_type));
        	data->GetParameter(SEVENPHOTONS_MAT_NODE, knd);
        	iSnodeDataType* kndData = static_cast<iSnodeDataType*> (knd.GetCustomDataType(SEVENPHOTONS_NODE_CUSTOMDATATYPE));
        	if(id[0].id == SEVENPHOTONS_MAT_PREVIEW)
        		return GetDParameterPreview(data, (GeData* )&t_data, flags, SEVENPHOTONS_MAT_PREVIEW, updatecount, (BaseMaterial* )node);
        	else if(kndData->selectedNode > 0)
        		if(kndData->nodes[kndData->selectedNode].getInternalCount() > 0)
        			for(Int32 i = 0; i < kndData->nodes[kndData->selectedNode].getInternalCount(); ++i)
        				Int32 ids = kndData->nodes[kndData->selectedNode].getInternalID(i);
        				if(id[0].id == ids)
        					if(kndData->nodes[kndData->selectedNode].getInternalDataType(i) & SEVENPHOTONS_NODE_ANYTHREE)
        						Vector vdata = (kndData->nodes[kndData->selectedNode].getInternalData(i)).GetVector();
        						HandleDescGetVector(id, vdata, t_data, flags);
        					else if(kndData->nodes[kndData->selectedNode].getInternalDataType(i) == SEVENPHOTONS_NODE_CURVE)
        						t_data = kndData->nodes[kndData->selectedNode].getInternalData(i);
        						flags |= DESCFLAGS_GET_PARAM_GET;
        					else
        						//data->SetString(ids, kndData->nodes[kndData->selectedNode].getName());
        					return MaterialData::GetDParameter(node, id, t_data, flags);
        		if(kndData->nodes[kndData->selectedNode].getInputCount() > 0)
        			for(Int32 i = 0; i < kndData->nodes[kndData->selectedNode].getInputCount(); ++i)
        				Int32 ids = kndData->nodes[kndData->selectedNode].getInputID(i);
        				//wire connected
        				if(kndData->nodes[kndData->selectedNode].getInputWireId(i) >= 0)
        					continue;
        				if(id[0].id == ids)
        					if(kndData->nodes[kndData->selectedNode].getInputDataType(i) & SEVENPHOTONS_NODE_ANYTHREE)
        						Vector vdata = (kndData->nodes[kndData->selectedNode].getInputData(i)).GetVector();
        					else
        						t_data = kndData->nodes[kndData->selectedNode].getInputData(i);
        Bool SevenPhotonsMaterial::SetDParameter(GeListNode* node, const DescID& id, const GeData& t_data, DESCFLAGS_SET& flags)
        	updatecount++;
        		return SetDParameterPreview(data, &t_data, flags, SEVENPHOTONS_MAT_PREVIEW);
        		//if(id[0].id == ++ids)
        		//	kndData->nodes[kndData->selectedNode].setName(t_data.GetString());
        		//	kndData->nodes[kndData->selectedNode].adjustSNode(false);
        		//	data->SetParameter(SEVENPHOTONS_MAT_NODE, GeData(SEVENPHOTONS_NODE_CUSTOMDATATYPE, *kndData));
        		//	return MaterialData::SetDParameter(node, id, t_data, flags);
        				if(id[0].id == ids)
        						HandleDescSetVector(vdata, id, vdata, t_data, flags);
        						kndData->nodes[kndData->selectedNode].setInternalData(i, GeData(vdata));
        						kndData->nodes[kndData->selectedNode].setInternalData(i, t_data);
        						flags |= DESCFLAGS_SET_PARAM_SET;
        					else
        				//wire connected
        					continue;
        				if(id[0].id == ids)
        						kndData->nodes[kndData->selectedNode].setInputData(i, vdata);
        					else
        						kndData->nodes[kndData->selectedNode].setInputData(i, t_data);
        tell me which portions you want, as I guess GeUserArea and CustomDataType portions are not needed here.
        I will post more code soon if needed.
          On 04/07/2015 at 09:54, xxxxxxxx wrote:
          I noticed that if I remove Get/SetDParamter() , I can't access the modified data, so I have to use them.
            On 10/07/2015 at 09:09, xxxxxxxx wrote:
            Hi Mohamed,
            terribly sorry, this took so long. I have to admit, I went down the wrong road all the way to the end, before I realized, I took the wrong branch. My fault!
            In Germany we say: Shooting yourself into your own knee. 😉
            Also I have no clean example code to post here, yet. But before entering my weekend, I still wanted to provide you some infos.
            Basically you were right in the beginning with your assumption, that it's similar to handling a vector. Unfortunately there's no macro nor any defines for the CUSTOMGUI_SPLINE.
            Here's how you do it manually:
            After checking, that your spline got addressed (id[0].id == your spline id), you need to check if id[1].id.
            If it is zero, t_data is of type CUSTOMDATATYPE_SPLINE. So you get a complete updated spline.
            If it is unequal zero, then you need to handle the "subchannels".
            If the id[1].id is greater 10000, you can use this:
            Int32 knotIdx = (id[1].id - 11100) / 100;
            Int32 partIdx = id[1].id - (11100 + (knotIdx * 100));
            knotIdx can be used directly with GetKnot().
            partIdx decodes as follows:
            0: position x
            1: position y
            2: left tangent x
            3: left tangent y
            4: right tangent x
            5: right tangent y
            I hope this helps. On Monday I will probably post some more code. Also there are more subchannels (that's why > 10000).
              On 10/07/2015 at 09:54, xxxxxxxx wrote:
              great
              about decoding partIdx, is this bit masks? (1 << 0, 1 << 1, ...) or just Int32 values?
              also waiting for all subchannels, the same for Gradient "as it is very similar, it has its post though"
              thanks for the help Andreas.
                On 10/07/2015 at 22:46, xxxxxxxx wrote:
                Hi Mohamed,
                no, it's not a bit mask, just integer. And the data you get is of type Float.
                  On 28/07/2015 at 17:45, xxxxxxxx wrote:
                  Hi Andreas,
                  I tried to fix the spline Get/SetDParameter, but this is a nightmare...
                  there are a lot of unknown description ids "not shown by show sub-channels"
                  any idea how to iterate over all sub channels and set/get as required?
                  here is what I did so far, works fine to some extent "tangents and point count are making a problem, if you animate point count the behavior is undefined"
                  inline void HandleDescGetSpline(const DescID &tid, SplineData *curve, GeData &t_data, DESCFLAGS_GET &flags)
                  	Int32 knotIdx = (tid[1].id - 11100) / 100;
                  	Int32 partIdx = tid[1].id - (11100 + (knotIdx * 100));
                  	CustomSplineKnot* knot = curve->GetKnot(knotIdx);
                  	switch(partIdx)
                  	default:
                  	case 0:
                  		t_data.SetFloat(knot->vPos.x);
                  		break;
                  	case 1:
                  		t_data.SetFloat(knot->vPos.y);
                  		break;
                  	case 2:
                  		t_data.SetFloat(knot->vTangentLeft.x);
                  		break;
                  	case 3:
                  		t_data.SetFloat(knot->vTangentLeft.y);
                  		break;
                  	case 4:
                  		t_data.SetFloat(knot->vTangentRight.x);
                  		break;
                  	case 5:
                  		t_data.SetFloat(knot->vTangentRight.y);
                  		break;
                  inline void HandleDescSetSpline(const DescID &tid, SplineData *curve, const GeData &t_data, DESCFLAGS_SET &flags)
                  	switch(partIdx)
                  	default:
                  	case 0:
                  		knot->vPos.x = t_data.GetFloat();
                  		break;
                  	case 1:
                  		knot->vPos.y = t_data.GetFloat();
                  		break;
                  	case 2:
                  		knot->vTangentLeft.x = t_data.GetFloat();
                  		break;
                  	case 3:
                  		knot->vTangentLeft.y = t_data.GetFloat();
                  		break;
                  	case 4:
                  		knot->vTangentRight.x = t_data.GetFloat();
                  		break;
                  	case 5:
                  		knot->vTangentRight.y = t_data.GetFloat();
                  		break;
                  						else if(kndData->nodes[mnode].getInternalDataType(i) == SEVENPHOTONS_NODE_CURVE)
                  							if(id[1].id == 0)
                  								kndData->nodes[mnode].setInternalData(i, t_data);
                  								data->SetParameter(DescID(id[0].id), t_data);
                  							else if(id[1].id == 1000)
                  								//kndData->nodes[mnode].setInternalData(i, GeData(1.f));
                  								//data->SetParameter(DescID(id[0].id, id[1].id), GeData(1.f));
                  								//flags |= DESCFLAGS_SET_PARAM_SET;
                  							else
                  								//SplineData *curve = (SplineData* )t_data.GetCustomDataType(CUSTOMDATATYPE_SPLINE);
                  								SplineData *curve = (SplineData* )(kndData->nodes[mnode].getInternalData(i)).GetCustomDataType(CUSTOMDATATYPE_SPLINE);
                  								HandleDescSetSpline(id, curve, t_data, flags);
                  							if(id[1].id == 0)
                  								t_data = GeData(CUSTOMDATATYPE_SPLINE, *(kndData->nodes[mnode].getInternalData(i)).GetCustomDataType(CUSTOMDATATYPE_SPLINE));
                  								//t_data.SetFloat(1.f);
                  								//flags |= DESCFLAGS_GET_PARAM_GET;
                  							else
                  								HandleDescGetSpline(id, curve, t_data, flags);
                    On 25/08/2015 at 08:56, xxxxxxxx wrote:
                    By now, there's an example on GitHub, demonstrating this.
                      On 25/08/2015 at 10:09, xxxxxxxx wrote:
                      thanks Andreas, is it the same?
                        On 26/08/2015 at 08:53, xxxxxxxx wrote:
                        To explain Mohamed's question: We were in direct communication and he received the example before it got published on GitHub.
                        @Mohamed: Yes, it's basically the same.
