    Connecting polygon points.
    6 Posts 0 Posters 722 Views
      On 18/06/2015 at 18:17, xxxxxxxx wrote:
      Hello everyone,
      i'm trying to acomplish airplanes route animation and stuck at connecting two points with spline.
      1. I parsed data from orouostai.cvs
      _<_t_>_ -17.3542 | , | -145.4961 | , | AER
      31.0733 | , 33.8358 , KZN
      36.8222 | , 7.8094 , OVB
      29.7275 | , -85.0274 , CEK _
      import csv
      import re
      filepath = r'D:\Grafikos Dizainas\Projects\LRT\Plazmos grafika\JM\C4D\python\data\orouostai.csv'
      scale = 10
      def GetData(source) :
          data = list()
          with open(source, 'r') as csvdata:
              dataset = csv.reader(csvdata, delimiter=',')
              for row in dataset:
                  pattern = re.compile("[A-Z]{3}|[A-Z]{1}[0-9]{2}")
                  search = pattern.search(row[-1])
                  abbr = search.group(0)
                  data.append('%s, %s, %s' % (abbr, row[0], row[1]))
          csvdata.close()
          data.sort()
          return data
      def DrawData(source) :
          container = c4d.BaseObject(c4d.Opolygon)
          container.ResizeObject(len(source), 1)
          for i in range(0, len(source)) :
              row = source[i].split(',')
              x = float(row[1]) * scale
              y = float(row[2]) * scale
              container.SetPoint(i, c4d.Vector(x, 0, y))
          doc.InsertObject(container, None, None)
          container.Message(c4d.MSG_UPDATE)
      DrawData( GetData(filepath) )
      i got all points in place, but how join whem with curved spline by airport name from another cvs file marsrutai.cvs
      _p> AER ' KZN
      ASF | ' KZN
      ASF | ' MRV
      CEK | ' KZN
      CEK | ' OVB_
      Sincerely, D.
        On 19/06/2015 at 06:53, xxxxxxxx wrote:
        Hello and welcome,
        what exactly is your question? Do you want to create a SplineObject?
          On 19/06/2015 at 09:07, xxxxxxxx wrote:
          I want to join airport point with curved spline. i want to create something like this
          creating spline lines, use splines as paths and move particles with tracer. But i don't know how to get values from marsrutai.csv and search it in orouostai.csv to get coordinates (longtitude latitude). for example.
          In orouostai.csv i have all my airports short names and coordinates. In marsrutai.csv i have all flight routes with airports shortnames.
          orouostai.csv ->
          (airport shortname) AAA, 54.687156, 25.279651 (coordinates)
          marsrutai.csv ->
          (origin) AAA - BBB (destination)
          Sincerely, D.
            On 20/06/2015 at 12:15, xxxxxxxx wrote:
            If I get you correctly, you already have all airports in the scene, right?
            Now all you need is to connect them, am I correct?
            In this case, let's say, you have 2 null objects in the scene: 1 - AER and 2 - KZN airports. Both these nulls are named exactly as you have them in marsrutai.csv.
            So, logical way to do next is to parse marsrutai.csv, and get 2 airports (AER and KZN). Then do search in Object Manager to find these airports, get those coordinates, and draw a Spline Object.
            Yes, No, Yes?? I this that should work.
            Sveikas atvykes i ekspertu foruma:) (welcome to the forum)
              On 21/06/2015 at 02:43, xxxxxxxx wrote:
              I have one polygon object with all airport points in it. Or i nees to create all 6k null objects to join them?
              Sveikas, nesitikėjau lietuvį susitikti čia :)) labai smagu!
                On 23/06/2015 at 13:39, xxxxxxxx wrote:
                This does not have to be null objects. I just used them for example, as it's easier for me to depict what's going on in the scene.
                Does your airpots are represented as a vertex point or a polygon? In both cases, just look up for that particular vertex or polygon ID and match it to your airpot.
                P.S. We can discuss this eye to eye:) just call me. My contacts are on my page.
