    Q: Image Buttons?
    4 Posts 0 Posters 665 Views
      On 26/01/2003 at 23:53, xxxxxxxx wrote:
      Cinema 4D Version:   7
      Hi
      There are a couple of Question I have:
      • Can I implement imagebuttons?
      • Can I make a tool button? (A button that works like the selection or move tool, that automaticly deactivates the previous tool-button)
      • Can I implement the move/scale buttons like in the image viewer or the 3D View?
      • How can I check which tool (selecting, move, scale, rotate ...) is active? I get a message when the tool is changed, but I can't figure out how to extract the needed information...
      • Where can I find out what the messages mean/is there a message documentation?
      Can anything above be programmed in COFFEE?
      Thanks in advance
      cya
        On 27/01/2003 at 06:42, xxxxxxxx wrote:
        Hi Zed,
        > * Can I implement imagebuttons?
        > * Can I make a tool button? (A button that works like the selection or move tool, that automaticly deactivates the previous tool-button)
        I don't know if you can send inter-plugin messages in XL7. But you can create several plugins (in this case MENUPLUGINS) in one CDL-File and keep track of the current selection of your tool with a global status.
        > * Can I implement the move/scale buttons like in the image viewer or the 3D View?
        I don't know, but I dont't think that this is possible easily.
        > * How can I check which tool (selecting, move, scale, rotate ...) is active? I get a message when the tool is changed, but I can't figure out how to extract the needed information...
        If you have a MENUPLUGIN, your Execute() callback function will get a BaseDocument parameter, say "doc". You can check the current editor mode with doc->GetMode().
        > * Where can I find out what the messages mean/is there a message documentation?
        I asked this here some time ago:
        <[URL-REMOVED]>
        In R8 the message handling has been simplified - see "Core Messages" in docu.
        Hope that helps. Ciao,
        Marcus
          On 27/01/2003 at 06:48, xxxxxxxx wrote:
          Uuuups, I didn't see/read that want to code in COFFEE. Ehem, well, then forget my answers. It was for the C++ SDK. Perhaps you can do something analogous, but I don't know. Sorry...
          Marcus
            On 27/01/2003 at 14:06, xxxxxxxx wrote:
            NNIC ("No, not in C.O.F.F.E.E."), except that some of the message documentation in the linked thread above applies to C.O.F.F.E.E. as well.
            Also, in C++ you would make a "tool button" by creating a tool plugin and adding it as a button from the Command Manager.
