    How to get DescIDs [SOLVED]
    8 Posts 0 Posters 828 Views
      On 16/06/2015 at 00:52, xxxxxxxx wrote:
      Hi!
      I'm finding it way too difficult to get DescIds of some parameters. Even if we drag that parameter we dont know what data type it is. How the hell should i know that VISIBILITY_IN_EDITOR takes Float or Long?
      If there is any reference to it pls tell.
        On 16/06/2015 at 00:54, xxxxxxxx wrote:
        To read the parameter, even if you want to create a DescID instead of just plain using the integer ID
        of the parameter, you don't need to know the datatype.
        value = op[c4d.VISIBILITY_IN_EDITOR]
        value = op[c4d.DescID(c4d.DescLevel(c4d.VISIBILITY_IN_EDITOR, 0, 0))]
          On 16/06/2015 at 00:58, xxxxxxxx wrote:
          No. i dont want to read it. i want to use it to create animation  tracks. I am trying to copy parameters of one animation tracks to another empty track. So i need complete DescID.
          Like for position track we use:
          11
          12
          trackX ``= c4d.CTrack(op,
                              ``c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_POSITION,c4d.DTYPE_VECTOR,``0``),
                                         ``c4d.DescLevel(c4d.VECTOR_X,c4d.DTYPE_REAL,``0``)))
          trackY ``= c4d.CTrack(op,
                                         ``c4d.DescLevel(c4d.VECTOR_Y,c4d.DTYPE_REAL,``0``)))
          trackZ ``= c4d.CTrack(op,
                                         ``c4d.DescLevel(c4d.VECTOR_Z,c4d.DTYPE_REAL,``0``)))
          op.InsertTrackSorted(trackX)
          op.InsertTrackSorted(trackY)
          op.InsertTrackSorted(trackZ)
          _<_t_>_
            On 16/06/2015 at 02:31, xxxxxxxx wrote:
            this should help to identify a desclevel id and the corresponding dtype:
              tracks = op.GetCTracks()
              print tracks
              for t in tracks:
                  tr =  t.GetDescriptionID()
                  print tr, "desc id"
                  print tr[0],"first desc level"
                  print tr[0].dtype
                  print tr[0].id
                  print tr[1],"second desc level"
                  print tr[1].dtype
                  print tr[1].id
            Best wishes
            Martin
              On 16/06/2015 at 06:40, xxxxxxxx wrote:
              GUI elements in Cinema 4D are often defined in resource files. These resource files are located in the "resource" folder of your installation and include both the ID of a parameter and its type. So if you are in doubt about a parameter type the corresponding resource file would tell you. Some more information on this can be found in the documentations:
              • Descriptions in Cinema 4D
              • Introduction into the GUI of Cinema 4D
              • Description Resource
              • Plugin Directory Structure
                On 03/07/2015 at 09:32, xxxxxxxx wrote:
                Hello CreamyGiraffe,
                was your question answered?
                  On 03/07/2015 at 10:48, xxxxxxxx wrote:
                  Yes Sebastian!
                  Thanks for prompt replies!!
                    On 10/12/2015 at 09:08, xxxxxxxx wrote:
                    Hey, I stumbled upon this post myself trying to figure out how to copy animation from one object to another with python. Could you just use GetClone to make a copy of the track instead of making a new one? I guess it is not as specific so might not be of use but just wanted to put it up.
                    tracks = objectA.GetCTracks()
                    for track in tracks:
                         clonedTrack = track.GetClone()
                         objectB.InsertTrackSorted(clonedTrack)
