    Detecting if a BaseObject is a Generator [SOLVED]
    6 Posts 0 Posters 830 Views
      On 12/06/2015 at 16:10, xxxxxxxx wrote:
      Is it possible to detect if an object has a Generator checkmark? I can detect if a generator is unchecked, but for objects that don't have a checkmark (like a Null) they always return true when I try:
      generator_on = obj[c4d.ID_BASEOBJECT_GENERATOR_FLAG]
      I'm currently checking objects against a manually generated list of exempted types, but I'd like to know if there's a better way, because if I forget to include a type, or a new object type is added to cinema, my code will break:
      def is_muted(obj) :
          """Return True if object is hidden in editor, renderer, and disabled."""
          if debug:
              print "is_muted(%s)" % (obj.GetName())
          if (obj is None) or (not obj.IsAlive()) :
          #Determine visibility based on `Visible in Editor/Renderer` not set to `Off`
          visible_in_editor = (obj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] != 1)
          visible_in_render = (obj[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] != 1)
          if visible_in_editor or visible_in_render:
              if debug:
                  print "Visible in editor/renderer", obj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR]
              return False
          #If the generator flag is on, and it's not a special type, the object isn't mute.
          generate = obj[c4d.ID_BASEOBJECT_GENERATOR_FLAG]
          if generate:
              if debug:
                  print "Generate is on"
              obj_type = obj.GetType()
              exempted_types = [c4d.Opolygon,
                                c4d.Onull,
                                c4d.Ospline,
                                c4d.Ocamera,
                                c4d.Ofloor,
                                c4d.Osky,
                                c4d.Oenvironment,
                                c4d.Oforeground,
                                c4d.Obackground,
                                c4d.Ojoint,
              if obj_type not in exempted_types:
                  return False
        On 13/06/2015 at 01:53, xxxxxxxx wrote:
        Hi Donovan,
        it´s a workaround for sure and there might be a simpler method, but trying to access the parameter gives you a clear result.
          generator_check = op[c4d.ID_BASEOBJECT_GENERATOR_FLAG]
          if generator_check == 1:
              op[c4d.ID_BASEOBJECT_GENERATOR_FLAG] = 0
              op[c4d.ID_BASEOBJECT_GENERATOR_FLAG] = 1
          if not op[c4d.ID_BASEOBJECT_GENERATOR_FLAG] == generator_check:
              op[c4d.ID_BASEOBJECT_GENERATOR_FLAG] = generator_check
              print "real generator"
        Best wishes
        Martin
          On 13/06/2015 at 04:32, xxxxxxxx wrote:
          an object is a generator when you use the OBJECT_GENERATOR flag when you register that object. You can read these flags using GetInfo(). Then you can check if the generator flag is set with something like this:
          info = op.GetInfo()
          if info & c4d.OBJECT_GENERATOR:
               print("Generator")
               print("No Generator")
            On 13/06/2015 at 06:40, xxxxxxxx wrote:
            It also has a checkmark when its a deformer, in case you want to
            check that as well, use the OBJECT_MODIFIER flag. 🙂
              On 14/06/2015 at 12:28, xxxxxxxx wrote:
              @monkeytack - I was hoping to avoid getting/setting the generator state as I'm using it in the Command Enable/Toggle code and it felt like that could get expensive, but that was going to to be my next strategy. Thanks for the working code.
              @s_bach - That's exactly what I was looking for. It feels like this might bear mentioning in the BaseObject docs as that's where I thought to look for the information.
              @niklas - Perfect, that makes it even more robust.
              Thank you guys! Here's my code for testing if something is an active generator/deformer.
                  #Is it a generator or deformer?
                  obj_info = obj.GetInfo()
                  is_generator = obj_info & c4d.OBJECT_GENERATOR
                  is_deformer = obj_info & c4d.OBJECT_MODIFIER
                  if is_generator or is_deformer:
                      print "Obj is a generator/deformer"
                      #Is it turned on?
                      if generate:
                          print "Generator/deformer is active."
                On 15/06/2015 at 11:44, xxxxxxxx wrote:
                I think you should prefer obj.GetDeformState() over reading the ID_BASEOBJECT_GENERATOR_FLAG parameter.
