    Image2Vertex map
    3 Posts 0 Posters 437 Views
      On 08/06/2015 at 16:39, xxxxxxxx wrote:
      Because i get so much help in the internet I want to share my plugin here.
      I used code fragments from here and there...
      It is a Bitmap to Vertexmap helper.
      The Script load a Bitmap from a texture tag. From color channel or alpha channel, or from a seperate file.
      Then it convert the bitmap to a vertexmap.
      Code is comment in german.
      Maybe someone helps:
      http://www.total3d.de/?page_id=550
      Code can surely be much better. (Like my english)
      But it works 😉
      import os
      from c4d import bitmaps, storage
      from c4d import utils,gui
      from c4d.gui import GeDialog
      from c4d.modules import render
      import math
      chlist = []
      scaleart = 0
      button = 0
      alpha = 0
      orig = bitmaps.BaseBitmap()
      objekttext = ""
      showo = False
      shows = False
      bitmapfile = ""
      # Dialog erstellen
      class Dialog(GeDialog) :
          global objekttext, showo, shows
          def __init__(self) :
              pass
          # Layout definieren
          def CreateLayout(self) :
              # Objektname in Beschreibungstext einfügen
              objekttext = "Selected object is: "+op.GetName()
              self.SetTitle("RenameTexture")    # Titel definieren
              self.GroupBegin(1000,c4d.BFH_CENTER|c4d.BFH_SCALE|c4d.BFH_FIT,0,8)
              self.AddStaticText(1001,c4d.BFH_CENTER|c4d.BFH_SCALE|c4d.BFH_FIT,800,10,"This is a simple image to vertex map converter!",0);
              self.AddStaticText(1007,c4d.BFH_CENTER|c4d.BFH_SCALE|c4d.BFH_FIT,800,10,"Use at your own risk - Please save Document before use!",0);
              self.AddSeparatorH(0,c4d.BFV_FIT)
              self.AddStaticText(1009,c4d.BFH_CENTER|c4d.BFH_SCALE|c4d.BFH_FIT,800,10,"1) Please select an object.",0);
              self.AddStaticText(1011,c4d.BFH_CENTER|c4d.BFH_SCALE|c4d.BFH_FIT,800,10,"2) Plugin use the first uvw tag of the select polygon object.",0);
              self.AddStaticText(1012,c4d.BFH_CENTER|c4d.BFH_SCALE|c4d.BFH_FIT,800,10,"3) Please select a textur tag at the object.",0);
              self.AddStaticText(1012,c4d.BFH_CENTER|c4d.BFH_SCALE|c4d.BFH_FIT,800,10,"4) Choose a button for use color map, alpha map or load a bitmap file.",0);
              self.GroupEnd()
              self.GroupBegin(1010,c4d.BFH_LEFT,1,1)
              self.AddStaticText(1008,c4d.BFH_LEFT,800,10,objekttext,0);
              self.GroupEnd()
              self.GroupBegin(1010,c4d.BFH_LEFT,2,4)
              self.AddCheckbox(1003,c4d.BFH_LEFT,10,10,"Bitmap COLOR Channel\n To Vertex Map!")
              self.AddStaticText(1012,c4d.BFH_LEFT,800,10,"Show Bitmap in the picture manager",0);
              self.AddCheckbox(1004,c4d.BFH_LEFT,10,10,"Bitmap COLOR Channel\n To Vertex Map!")
              self.AddStaticText(1014,c4d.BFH_LEFT,800,10,"Show scaled bitmap in picture manager",0);
              self.GroupEnd()
              self.GroupBegin(1000,c4d.BFH_LEFT|c4d.BFH_SCALE|c4d.BFH_FIT,1,3)
              self.AddStaticText(1001,c4d.BFH_LEFT,800,10,"How much scale the bitmap before check color :",0);
              self.AddEditSlider(1002,c4d.BFH_LEFT|c4d.BFH_SCALE|c4d.BFH_FIT, 10, 0)
              self.GroupEnd()
              self.AddSeparatorV(0,c4d.BFV_FIT)
              self.GroupBegin(1020,c4d.BFV_CENTER,3,1)
              self.AddButton(1022,c4d.BFH_CENTER,0,40,"Bitmap COLOR Channel\n To Vertex Map!")
              self.AddButton(1023,c4d.BFH_CENTER,0,40,"Bitmap ALPHA Channel\n To Vertex Map!")
              self.AddButton(1024,c4d.BFH_CENTER,0,40,"Load a Bitmap File\n To Vertex Map!")
              self.GroupEnd()
          # Dialog Verarbeitung definieren
          def Command(self,id,msg) :
              global chlist, scaleart, orig, alpha, button, showo, shows, bitmapfile
              button = id    # Variable button für Benutzung im Hauptprogramm speichern
              if(id < 1002 or id > 1005) :# Wurde nur der Slider, oder die Checkboxen verändert? Dann mit True zurückgeben
                  if(id == 1022 or id == 1023) : # Button links oder mitte (Color oder Alpha) wurde gedrückt
                     # Button 1 (Alpha Channel) gedrückt
                     if (id == 1023) : alpha = 1
                     #Scalierungs Slider speichern
                     scaleart = int (self.GetReal(1002) * 0.1)
                     showo= self.GetBool(1003)
                     shows= self.GetBool(1004)
                     self.Close()    # Fenster schließen und weiter im Hauptprogramm
                     if (id == 1024) :# Der Button rechts für die Datei-Auswahl wurde gedrückt
                          # Datei-Dialog öffnen
                          bitmapfile = c4d.storage.LoadDialog (type=c4d.FILESELECTTYPE_IMAGES, title="Select a bitmap file for mapping!", flags=c4d.FILESELECT_LOAD)
                          if not bitmapfile:
                              gui.MessageDialog("no File loading!")
                              return False
                          self.Close()
                          self.Close()
                          return False
          # globale Variablen übernehmen
          global scaleart, orig, alpha, button, showo, shows, bitmapfile
          c4d.CallCommand (13957) # Pythonkonsole leeren
          # Objekt ausgewählt? Sonst Fehlerausgabe und beenden
          if not op:
              gui.MessageDialog("Please select a object!")
              return False                        # EXIT
          # Prüfen ob das Objekt ein Polygonobjekt ist
          if (op.GetType()== 5100) :           # 5100 ist der Type für das Polygonobjekt
              print
              gui.MessageDialog("ERROR - Object is not a polygon object?")
              return False
          # Erstes UVTag auslesen
          uvtag = op.GetTag(c4d.Tuvw)
          # Kein UVW Tag? Sonst Fehlerausgabe und beenden
          if not uvtag:
              gui.MessageDialog("Please assign UVW to the object")
          # Dialog aufrufen
          dlg = Dialog();
          dlg.Open(c4d.DLG_TYPE_MODAL)
          if (button == 0) : return False    # Kein Button gedrückt (z.B. beim Fenster schließen über Fensterelement X)
          # Bitmap Variablen vorbereiten
          smallbitm = bitmaps.BaseBitmap()
          bitmap = bitmaps.BaseBitmap()
          bitmapPath = bitmapfile
          if (button == 1024) :
              abspath = bitmapfile
              # Selektiertes Tag auslesen
              ttag = doc.GetActiveTag()
              if (not ttag or not ttag.CheckType(c4d.Ttexture) ) : # Falls kein Material Tag vorhanden oder/und ausgewählt - abbrechen
                  gui.MessageDialog("Please attach AND SELECT a Material to the object!")
                  return False
              # Material der Variable mat zuweisen
              mat = ttag.GetMaterial()
              # Kein Material übernehmen können? Dann Fehlerausgabe und beenden
              if not mat:
                  gui.MessageDialog("Please attach a Material with simple bitmap in color Channel to the object!")
                  return False # EXIT
              # Farbkanal auslesen falls Variable alpha = 0 (Button links gedrückt)
              if (alpha == 0) :
                  if (mat[c4d.MATERIAL_USE_COLOR] == True) : # ist der Color kanal des Materials aktiv?
                     shader = mat[c4d.MATERIAL_COLOR_SHADER] # dann Shader auslesen
                     gui.MessageDialog("Miss COLOR Channel!")
                     return False # Exit
              # Alphakanal auslesen falls Variable alpha = 1 (Button mitte gedrückt)
              if (alpha == 1) :
                  if (mat[c4d.MATERIAL_USE_ALPHA] == True) : # ist der Alpha kanal des Materials aktiv?
                     shader = mat[c4d.MATERIAL_ALPHA_SHADER] # dann Shader auslesen
                     gui.MessageDialog("Miss ALPHA Channel!")
                     return False # Exit
              # Farbkanal / Alphakanal konnte nicht gelesen werden?
              if shader is None:
                  if (alpha == 0) : gui.MessageDialog("Can't get the Shader!\nPlease check that the COLOR Channel is not empty!")
                  if (alpha == 1) : gui.MessageDialog("Can't get the Shader!\nPlease check that the ALPHA Channel is not empty!")
                  return False # EXIT
              # Shader vor dem auslesen erst abrufbar machen!!!
              bitmapPath = shader[c4d.BITMAPSHADER_FILENAME]
              # Shadertyp und Filename bei Bitmapshader auslesen
              name, path = shader.GetName(), shader[c4d.BITMAPSHADER_FILENAME]
              #if bitmapPath is´nt absolute
              if not os.path.dirname(bitmapPath) :
                  #the document has´nt been saved already ->picture in user library
                  if not doc.GetDocumentPath() :
                     abspath= c4d.storage.GeGetStartupWritePath()+"/"+"tex"+"/"+bitmapPath
                  #the picture should be inside the asset´s texture folder
                     abspath= doc.GetDocumentPath()+"/"+bitmapPath
                  abspath = bitmapPath
          if op is not None:
              # Bitmap mit vollem Pfad und Dateinamen Initialisieren:
              result = bitmap.InitWith(abspath)
              if (button <> 1024) : irs = render.InitRenderStruct()
              else: irs = True
              if (button <> 1024) : shader.InitRender(irs)
              if irs:
                  # Bitmapdateien in Shadern können absolut oder relativ gespeichert werden.
                  # Also muss geprüft werden ob der komplette Pfad ausgelesen wurde!
                  # Falls Bitmap ordnungsgemäß verarbeitet wurde:
                  if result:
                     # Die Variable bitmap wurde jetzt auf eine von 3 Arten befüllt:
                     if bitmap is not None: # hats geklappt? Dann weiter:
                          width, height = bitmap.GetSize()       # Pixel-Maße der Bilddatei auslesen
                          bits = bitmap.GetBt()                  # Bittiefe auslesen
                          pixelzahl = width*height               # Gesamtpixelanzahl ermitteln
                          punktezahl = uvtag.GetDataCount()      # Punkteanzahl der UVW-Map ermitteln
                          # Scalierung auf basis des Skalierungs-Sliders berechnen
                          # Aufgrund der Differenz der Auflösung der Bilddatei
                          # und der Auflösung des Polygonmesh (bzw. der UVW-Map)
                          # berechnet sich die Scalierung der Bilddatei.
                          # Die Bilddatei wird skaliert damit in einer hohen Bildauflösung
                          # ein einzelner ausgerissener Pixel den Punkt in einem niedrig aufgelösen Mesh                        # nicht so stark beeinflusst beeinflusst. nur weil der UV-Punkt genau auf diesem Pixel liegt.
                          differenz = pixelzahl - punktezahl             # Differenz ermitteln
                          if scaleart == 10: diffadd = float(differenz)/1000    # Neue Bildgröße = Anzahl der Punkte der UV-Map + Differenz geteilt durch 1000
                          if scaleart == 9: diffadd = float(differenz)/500     # Neue Bildgröße = Anzahl der Punkte der UV-Map + Differenz geteilt durch 500
                          if scaleart == 8: diffadd = float(differenz)/100      # Neue Bildgröße = Anzahl der Punkte der UV-Map + Differenz geteilt durch 100
                          if scaleart == 7: diffadd = float(differenz)/50       # Neue Bildgröße = Anzahl der Punkte der UV-Map + Differenz geteilt durch 50
                          if scaleart == 6: diffadd = float(differenz)/20       # Neue Bildgröße = Anzahl der Punkte der UV-Map + Differenz geteilt durch 20
                          if scaleart == 5: diffadd = float(differenz)/10       # Neue Bildgröße = Anzahl der Punkte der UV-Map + Differenz geteilt durh 10
                          if scaleart == 4: diffadd = float(differenz)/5        # Neue Bildgröße = Anzahl der Punkte der UV-Map + Differenz geteilt durch 5
                          if scaleart == 3: diffadd = float(differenz)/3        # Neue Bildgröße = Anzahl der Punkte der UV-Map + ein Drittel der Differenz
                          if scaleart == 1: diffadd = float(differenz)/2        # Neue Bildgröße = Anzahl der Punkte der UV-Map + die Hälfte der Differenz
                          if scaleart == 2: diffadd = float((differenz/3))*2    # Neue Bildgröße = Anzahl der Punkte der UV-Map + Zwei Drittel der Differenz
                          if scaleart == 0: diffadd = differenz          # Neue Bildgröße = Anzahl der Punkte der UV-Map + komplette Defferenz - Also volle Auflösung!
                          # Geladenes Bild bestimmt das Seitenverhältnis. Anhand der alten Menge an Pixel,
                          # der zur Verfügung stehenden Punkte im UV-Mesh und dem Grad der Skalierung (Slider)
                          # wird die neue Bildgröße berechnet. mit gleich bleibenden Seitenverhältnis.
                          # Scalierungsfaktor berechnen: Punkte+Pixelreduzierung geteilt durch Pixelanzahl
                          scalefaktor = float(punktezahl+diffadd) / (pixelzahl)
                          # Anhand des Skalierungsfaktors der Fläche die Seitenlängen berechnen
                          scale_width = int(width * math.sqrt(scalefaktor))
                          scale_height = int(height * math.sqrt(scalefaktor))
                          # Kleinere Version der Bitmap erstellen
                          smallbitm.Init(scale_width, scale_height, bits)    # Kleinere Maße, gleiche Bittiefe, gleiches Seitenverhältnis
                          # Copy&Scale; Original Bitmap zu Kleine Bitmap
                          bitmap.ScaleBicubic(smallbitm, 0, 0, width-1, height-1, 0, 0, scale_width-1, scale_height-1)
                          if (showo == True) : bitmaps.ShowBitmap(bitmap)
                          if (shows == True) : bitmaps.ShowBitmap(smallbitm)
                          bitmap = smallbitm
                          gui.MessageDialog("Bitmap-Error")
                          return False
                     if (button <> 1024) : shader.FreeRender()
                     # Abbrechen falls Bitmap nicht übergeben werden konnte
                     if bitmap is None:
                          gui.MessageDialog("Bitmap can't load")
                          return False
                     # Im Kanal steckt keine einfache Bitmap-Datei. Wahrscheinlich ein prozeduraler Shader, oder Ebenen ect.
                     gui.MessageDialog("In channel ist not a simple bitmap")
                     return False                           # EXIT
                  # Es wird eine Vertexmap erstellt die gleichviele Punkte enthält wie das Polygonobjekt
                  vtag = c4d.VariableTag(c4d.Tvertexmap, op.GetPointCount())
                  bitmap_w = bitmap.GetBw()              # Breite der Bitmap auslesen
                  bitmap_h = bitmap.GetBh()              # Höhe der Bitmap auslesen
                  pixel = (bitmap_w * bitmap_h)          # Pixelanzahl des Skalierten Bildes
                  points = uvtag.GetDataCount()          # Punktanzahl des UVW-Tags
                  if (op.GetPointCount() > 0) :           # Prüfen ob das Objekte Punkte zum auslesen hat
                     vertexList = op.GetPointCount() * [0] # Die Variable für die Vertagsmap-Befüllung mit der Anzahl an Punkten des selektierten Objektesvorbereiten
                     gui.MessageDialog("Object have no read able points! Is it a polygon object?")
                     return False
                  # Schleife liest jedes UVW-tag Polygon aus. Ein Punkt eines UVW-Tags kann mehreren Polygonobjekt-Punkten zugewisen sein
                  # Es wird der Reihe nach jedes UV-Polygon ausgelesen. Dann wird das zugehörige Polygon des Objektes ausgelesen und
                  # dessen Punkte mit den Farbwerten der Bitmap gefüllt. Die Anzahl der Polygonpunkte müssen nämlich gleich sein mit der Anzahl der Vertexmap-Punkte
                  # Laut Wiki: Grauwert = 0,299 × Rotanteil + 0,587 × Grünanteil + 0,114 × Blauanteil
                  for i in xrange(uvtag.GetDataCount()) : # Schleife durchläuft Polygone des UVW-Tag
                          uvwdict = uvtag.GetSlow(i)     # UVW-Polygon wird eingelesen
                          objpolygon = op.GetPolygon(i) # Objekt-Polygon wird eingelesen
                          point_a = op.GetPoint(objpolygon.a) # Objekt Polygon-PunktA ID wird ausgelesen
                          point_b = op.GetPoint(objpolygon.b) # Objekt Polygon-PunktB ID wird ausgelesen
                          point_c = op.GetPoint(objpolygon.c) # Objekt Polygon-PunktC ID wird ausgelesen
                          point_d = op.GetPoint(objpolygon.d) # Objekt Polygon-PunktD ID wird ausgelesen
                          u = uvwdict["a"].x                  # UVW-Koordinate des Punktes A wird ermittelt
                          v = uvwdict["a"].y                  # UVW-Koordinate des Punktes A wird ermittelt
                          w = uvwdict["a"].z
                          ux = bitmap_w*u                     # UV-Koordinate liegt zwischen 0-1 und wird mit der Bildbreite multipliziert
                          uy = bitmap_h*v                     # UV-Koordinate liegt zwischen 0-1 und wird mit der Bildhöhe multipliziert
                          color = bitmap.GetPixel(int(ux), int(uy))
                          # "ubjektiver" Helligkeitswert aus RGB ermitteln
                          weight_a = 0.299 * (float(color[0])/256) + 0.587 * (float(color[1])/256) + 0.114 * (float(color[2])/256)
                          u = uvwdict["b"].x                  # UVW-Koordinate des Punktes B wird ermittelt
                          v = uvwdict["b"].y                  # UVW-Koordinate des Punktes B wird ermittelt
                          w = uvwdict["b"].z
                          weight_b = 0.299 * (float(color[0])/256) + 0.587 * (float(color[1])/256) + 0.114 * (float(color[2])/256)
                          u = uvwdict["c"].x                  # UVW-Koordinate des Punktes C wird ermittelt
                          v = uvwdict["c"].y                  # UVW-Koordinate des Punktes C wird ermittelt
                          w = uvwdict["c"].z
                          weight_c = 0.299 * (float(color[0])/256) + 0.587 * (float(color[1])/256) + 0.114 * (float(color[2])/256)
                          u = uvwdict["d"].x                  # UVW-Koordinate des Punktes D wird ermittelt
                          v = uvwdict["d"].y                  # UVW-Koordinate des Punktes D wird ermittelt
                          w = uvwdict["d"].z
                          weight_d = 0.299 * (float(color[0])/256) + 0.587 * (float(color[1])/256) + 0.114 * (float(color[2])/256)
                          # Helligkeitswerte der Vertexmap Wert-Variable zuweisen
                          vertexList[objpolygon.a] = weight_a
                          vertexList[objpolygon.b] = weight_b
                          vertexList[objpolygon.c] = weight_c
                          vertexList[objpolygon.d] = weight_d
                  if vtag: # falls die Vertexmap auch wirlich erstellt wurde kann es weiter gehen:
                     op.InsertTag(vtag) # Vertexmap wird an dem objekt erstellt
                     vtag.SetAllHighlevelData(vertexList) # erstellte Vertexmap wird mit den ermittelten Werten gefüllt
                  c4d.EventAdd() # Veränderung in der Szene mitteilen, damit C4D aktualisiert.
                  # Das Vorbereiten der Bitmapinitialisierung hat fehlgeschlagen:
                  gui.MessageDialog("Can Not Init Shader")
                  if irs == c4d.INITRENDERRESULT_OUTOFMEMORY: gui.MessageDialog("Out Of Memory")
                  if irs == c4d.INITRENDERRESULT_ASSETMISSING: gui.MessageDialog("Texture Not Assigned")
                  if irs == c4d.INITRENDERRESULT_UNKNOWNERROR: gui.MessageDialog("Unknown Error")
                  if irs == c4d.INITRENDERRESULT_THREADEDLOCK: gui.MessageDialog("Threaded Lock")
              gui.MessageDialog(" - Finish - ")
        On 09/06/2015 at 01:09, xxxxxxxx wrote:
        thanks for sharing!
        As I wrote a similar plugin, last year, for an in house production I want to ask if you feel like working together and publish an optimized version with a few more features?
        If so, feel free to send me a pm.
        Best wishes
        Martin
          On 09/06/2015 at 08:11, xxxxxxxx wrote:
          thank you for sharing your work!
