    MIDI library. Possible?
    7 Posts 0 Posters 654 Views
      On 02/06/2015 at 15:04, xxxxxxxx wrote:
      Is it possible to include a midi library to be able to read values from midi devices?
      Probably, the library would be placed in:
      (Preferences Folder)/library/python/packages/
      If possible, what libraries (multi-platform if possible) would you advise me to use?
        On 02/06/2015 at 15:16, xxxxxxxx wrote:
        Check the Python Package Index if you can find a suitable library.
          On 03/06/2015 at 04:30, xxxxxxxx wrote:
          WOW! Impressive repository of python libraries, Niklas.
          Thank you 🙂
          I have found some stuff there, but the documentation is sooo unclear. Damn!!! Why must developers be so criptic? 😉
            On 03/06/2015 at 06:39, xxxxxxxx wrote:
            Hi Rui,
            actually I'm not sure, to which documentation you are referring? And if you have an actual problem?
              On 03/06/2015 at 08:31, xxxxxxxx wrote:
              I think he refers to the documentation of a library, Andreas. 🙂
                On 03/06/2015 at 08:42, xxxxxxxx wrote:
                Yeah, thought so, too. Nevertheless wanted to make sure.
                  On 03/06/2015 at 10:33, xxxxxxxx wrote:
                  Actually, the problem is that some libraries (the one in particular that I wanted to try) comes in .cpp format. That means it requires compiling, I guess. And there are not instructions to compile it. The developers assume that everyone know how to do it, I guess.
                  Also, that means that, if I wanted to create a plugin that would require that library, I would have to pre-compile it for Mac OS, for Windows 32bit and Windows 64bit.
                  Why don't they provide it pre-compiled and ready to install or copy to a folder?
