    AddShortcut() [SOLVED]
    2 Posts 0 Posters 300 Views
      On 02/06/2015 at 07:34, xxxxxxxx wrote:
      Cinema 4D Version:   R13.061
      Hi there,
      the problem:
      Our plugin needs access to the CTRL+"C",  CTRL+"V" and CTRL+"X" keyboard shortcuts. Meaning, the plugin must be started when the modeler uses these shortcuts in the scenegraph window.
      I experimented with the api and found the following issues:
      1.) adding the shortcut via  AddShortcut() does not work. AddShortcut()  returns True, but probably the shortcut is overwritten by a previous set shortcut?
      Here is the code i use:
        BaseContainer bc;
            bc.SetLong(SHORTCUT_PLUGINID, PID_CMD_AMT_COPY);
            bc.SetLong(SHORTCUT_ADDRESS, 0);
            bc.SetLong(SHORTCUT_OPTIONMODE, 0);
            bc.SetLong(0, 2);
            bc.SetLong(1, 67);
            Bool res= AddShortcut(bc);
      2.) Finding other shortcuts which use the same keys, removing them and then adding the shortcut does not work. Here is the code:
            BaseContainer bc;
            bc.SetLong(0, 2);
            bc.SetLong(1, 67);
            LONG nr= FindShortcuts(bc, shortCuts, sizeof(shortCuts)/sizeof(LONG));
            for (int i=0; i< nr; i++)
                Bool ok= RemoveShortcut(shortCuts[i]);        // failes
            Bool res= AddShortcut(bc); // succeeds, but does not work
      FindShortcuts() in the code above finds 2 shortcuts (indizes are: 13543,  12107), trying to remove them fails. LONG im= GetShortcutCount(); gives 319, so both these indizes are out of range.
      3.) The only way to assign the shortcut correctly is via  LoadShortcutSet(Filename("AMTShortcuts.txt"), FALSE); but this deletes all registered shortcuts, making it impossible for the modeler to set her own shortcuts. Using  LoadShortcutSet(Filename("AMTShortcuts.txt"), TRUE);  does not work.
      So how can I get these three shortcuts to work?
      Thanks in advance.
        On 03/06/2015 at 02:28, xxxxxxxx wrote:
        Just fyi, found a way how  to do it. Don't use FindShortcuts(), instead search all shortcuts manually, Remove() them and add your shortcut.
          // remove all global ctrl+c
              for (int i=0; i< im; i++)
                  BaseContainer bc= GetShortcut(i);
                  LONG commandID= bc.GetLong(SHORTCUT_PLUGINID);            // e.g: PID_CMD_AMT_COPY
                  LONG shortcutAdress= bc.GetLong(SHORTCUT_ADDRESS);        // 0
                  Bool shortcutOptionMode= bc.GetBool(SHORTCUT_OPTIONMODE); // 0
                  LONG shortcutQualifier= bc.GetLong(0);    // =2, probably ctrl
                  LONG shortcutKey= bc.GetLong(1);        // =67,  == ascii 'C'
                  if (shortcutAdress ==0 && shortcutOptionMode==0 && shortcutQualifier==2 && shortcutKey==67)
                      // found global CTRL+C
                      RemoveShortcut(i);
                      i--;
              // add ctrl+c:
              BaseContainer bc;
              bc.SetLong(0, 2);
              bc.SetLong(1, 67);
