    Line Drawing
    3 Posts 0 Posters 612 Views
      On 20/01/2003 at 06:17, xxxxxxxx wrote:
      Cinema 4D Version:   7.3
      Hey all,
      _<_img border="0" src= "http://www.cg.tuwien.ac.at/~mccool/c4dprob.gif"_>_
      I must be able to do what you see above -- extend two lines from a single point "b".
      Any help on how to do this is appreciated.
      If there is no such thing as "reusing" point b, I will need to write some stuff that draws a line between two arbitrary  points, some sort of "2-vertex-polygon", to do the job.
      Will this be possible in Coffee ?
        On 20/01/2003 at 14:14, xxxxxxxx wrote:
        It's a bit unclear what you really want to do. Generating geometry is possible in C.O.F.F.E.E., drawing in the editor is not. For 2-vertex-polygons you could use splines, though they won't render unless you use a Sweep NURBS or something like the Solid Spline plugin.
          Thank you very much, mikael, for your fast reply (it really helped). This stuff may sound weird - 2-vertex-polys etc., I use it for some algorithm where I need 3d lines (which is: 2-vertex-polys).
          I will use a fake 4-vertex poly (w/only two unique vertices) to emulate 2-vertex polys that _will_ be drawn.
