    Is SendModelingCommand allowed in Message?[SOLVED]
    6 Posts 0 Posters 547 Views
      On 12/05/2015 at 05:18, xxxxxxxx wrote:
      Cinema 4D Version:   R16
      Platform:      Mac OSX  ;
      I want to call MCOMMAND_CURRENTSTATETOOBJECT when a button is pressed.
      I should do this inside Message()'s MSG_DESCRIPTION_COMMAND, I guess, but if I try it my program crashes.
      Is this not possible inside Message?
      Here is my code:
      if (type == MSG_DESCRIPTION_COMMAND)
        DescriptionCommand* dc = (DescriptionCommand* )data;
        if (dc->id[0].id == MY_BUTTON)
            BaseDocument* doc = static_cast<BaseDocument*>(data);
            if (!doc)
                return false;
            BaseObject* myObject = doc->GetFirstObject();
            if (!myObject)
                return false;
            ModelingCommandData cd;
            cd.doc = doc;
            cd.op = myObject;
            SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, cd);
      Greetings,
      Casimir Smets
        On 12/05/2015 at 06:03, xxxxxxxx wrote:
        It is valid and safe. But you cannot simply cast data (which is a DescriptionCommand) into a basedocument coz it does not hold a basedocument pointer.
        You should use node->GetDocument() instead (or GetActiveDocument() which should be valid due to a button click most of the time only being triggered interactively..though this is no guarantee so node->GetDocument() is the better alternative).
        Also you might need to do this on a copy of the scene.
          On 12/05/2015 at 06:22, xxxxxxxx wrote:
          If I change that, I get no error, and my program doesn't quit.
          The only problem is, it is not making it editable..
          Greetings,
          Casimir Smets
            On 12/05/2015 at 06:32, xxxxxxxx wrote:
            Ignore my previous post 😉
            I forgot to cast it and add it to the scene, feeling stupid now yeeeuy 😄
            Greetings,
            Casimir Smets
              On 12/05/2015 at 07:50, xxxxxxxx wrote:
              Hi Casimir,
              Katachi is right with his answer.
              I sense some problems with the concept of casting datatypes here. It is certainly one of the more advanced concepts of C and C++ and probably one which is cause for many (if not most) bugs. As casts are needed in several places in the C4D SDK, I'd recommend to have a read on this topic.
              For example here or here or here. Especially the parts about casting pointers are crucial.
                On 13/05/2015 at 08:17, xxxxxxxx wrote:
                Hi Andreas,
                Thanks for your answer!
                I shall definately look more into casting!
                Greetings,
                Casimir Smets
